Question about Homedics Sound Spa Classic Clock Radio
Soundspa alarm clock worked great until i installed the 9 volt
Battery. All that is showing is a number 0, 1 or 2 on the led display.
Nothing else works unless I remomve the battery.
Thanks,
Scott
4 Suggested Answers
Melophilia
SOURCE: projection display
I had the some problem a few days ago when we had a power outage during the night. Try unplugging it, leave it unplugged for about 10-20 seconds, and replug it back in. Reset your time on the clock and it should work then.
Posted on Oct 01, 2008
SOURCE: homedics soundspa clock radio ss-4500
Setting the Clock
1. Press and hold the HOUR button for 5 seconds (Fig. 5). The time will begin to flash
2. While the time is flashing, press the HOUR button until you reach the correct hour. Then press the
MINUTE button (Fig. 5) until you reach the correct minute.
NOTE: PM indicator will appear on the left side of the clock face for evening hours (Fig. 5). If the
PM indicator is not illuminated, the hour is set to AM. Be sure to set the time for the correct
12-hour period – AM (morning) or PM (evening).
NOTE: After 5 seconds, the time will stop flashing and it will be set.
Posted on Nov 06, 2008
I had the same problem - the directions can now be found here: http://media.homedics.com/IBs/SS-4500_IB.pdf
Posted on Aug 03, 2009
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
How do you make it work with the 9 volt battery?
The 9-volt battery is a backup battery. It will keep the clock running and the alarm working when the power goes off so you won't be late for work.
Aug 26, 2011 | GE 7-4837 Clock Radio
I have had my radio for many years but when I wanted to put it in another room it displays a half "L" on the display when I plug it in. Do I have to replace the battery when I'm using an...
Hello
You haven't specified nothing about your Emerson Smartset Clock Radio. Nothing is there about its model number. Yet I posts this solution before you assuming that yours' is a CKS3528 Emerson Clock radio.
There is a long life lithium battery installed in this clock radio when you buy it.
This battery can maintain the time and alarm settings for 3 to 5 years, or even
longer, so there is no need to pay for a new 9-volt battery every 6 months, as
is recommended in other clock radios with normal battery back up.
But if this lithium battery has gone down [ in terms of voltage]; the display 'L" will be there. It means that, it is time to replace this backup battery. It will be of disc type, usually used as bios setting storage, used in computers. OK.
May 13, 2011 | Emerson Smartset Clock Radio
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Mar 26, 2011 | Audio Players & Recorders
Need the specs for the Homedics ss-5010 power adaptor
Product Attributes
Product attributeProduct Line: SoundSpa
Product attributeProduct Model: SS-5010
Product Summary
Manufacturer: Homedics
Mfg Part#: SS-5010
Buy.com Sku: 211467114
UPC: 031262038029
UPC 14: 00031262038029
Package Weight: 1.9 lbs
Buy.com Sales Rank: 64081
Advertisement middle
Features
Product Type Desktop Clock Radio
Manufacturer Part Number SS-5010
Manufacturer Website Address www.homedics.com
Manufacturer HoMedics EMEA
Product Model SS-5010
Product Name SoundSpa Premier SS-5010 Clock Radio
Product Line SoundSpa
Brand Name HoMedics
Frequency Band/Bandwidth AM/ FM
Tech Specs
Brand Name HoMedics
Frequency Band/Bandwidth AM/FM
Feb 13, 2011 | Audio Players & Recorders
Need set up instructions for the KATEC #38 travel alarm clock
I bought one of these for $3.00. I found it in the clearance sale aisle at my local Wal-Mart. The instructions refer to it as being an "Automobile Clock."
In the instructions, "M" refers to the "Mode" button, "S" refers to the "Set" button, and "D" refers to the "Date" button. These are the instructions that came my KATEC #38 travel alarm clock:
1. In normal mode, there will show hour, minute, second and week. Push "D" to show date and push "S" to show alarm-time.
2. Adjust alarm-time: Push "M" two times to enter into alarm mode. Push "S" to choose hour and minute. Push "D" to adjust the right time. Finally, push "M" to return.
3. Adjust real time: Push "M" three times to enter into adjust time mode. Push "S" to choose second, minute, hour, day, week, and month in order. Push "D" to adjust correspondence number for right volume. Finally, push "M" to return to norm-al mode.
4. Sport Function: Push "M" for one time into sport watch function mode. The beginning state is show as 0:00:00. Push "D" to enter into recording time. Push "D" again to stop. Push "S" to return to the beginning mode 0:00:00.
5. Adjust ON/OFF alarm mode. In normal state, push "S" and "D". You can choose alarm on or off. When alarm operates, the alarm symbol will be displayed on.
Jan 09, 2010 | GE 74801 Clock Radio
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
I can't reset my Atomic Traveling Alarm Clock C17DD2090(WIC#6930
First, make sure you have new batteries in it. Then you have two choices:
Hold down the 3rd button -- the antenna button -- until the little antenna sign displayed on the right starts blinking and "broadcasting"...and then wait for the clock to set itself.
When that doesn't work (LOL), try this:
Hold down the "Set" button until each of the various fields start blinking. Then press the up button (3rd one) or the down button (4th one) to adjust each field to the desired number, etc. At least, that's what my office technician did to set mine. Good luck.
Mar 25, 2009 | Honeywell RC182WR Atomic Alarm Clock - Red
OUTDOOR TEMPERATURE
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Sep 03, 2008 | SkyScan 86709 Atomic Wall Clock
Homedics Sound Spa Classic Clock Radio Logo
Top Homedics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Tom Chichester
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
