Question about Freezers
Magnet on freezer door no longer functions to maintain seal
Not aware of any action that may have caused this problem.
  • 1 more comment
  • northstar846 Dec 26, 2008
    Restatement of problem. The freezer door will not seal to the cabinet/frame. There have been no previous indications of any problem. What secures, i.e., seals, the door to the cabinet when the door is closed? Note: the seals are in good shape and clean. The unit is also square on the floor. Is the problem a parts problem, e.g., magnet? hinge? Adjustment problem? The problem could have occurred incrementally but without symptoms until the seal would not function or the problem could be a part or condition that simply occurred abruptly.
  • northstar846 Jan 06, 2009
    Condensation caused the magnetised seal from functioning. Once the freezer was free from frost, the door seal once again functioned.
  • Todd Born
    Todd Born May 11, 2010
    are you talking about the one for the gasket?
  • 700 Answers
Try putting parafin or wax in the seal to keep it from stickint and turning on yoiu. also try to repositionm the load inside of the compartment.
Posted on Jan 06, 2009
  • Freezers Master
  • 3,463 Answers
Make sure the door is not out of alignment,and nothing is preventing the door from closing properly, check for loose or broken door hinge..
Plz leave comment.Thanks.
Posted on Dec 25, 2008
  • Barry Coates
    Barry Coates Dec 28, 2008
    Further to your prob with freezer door seal.
    If you have not solved it yet, try placing a thin piece of metal or pin or something like that against the seal, if it is still magnetised then it is o/k, if it won't hold metal then the seal needs replacing.
    Try this all the way round the seal.
    Plz let me know how you get on.
    thanks
Why is my Hoover A Class upright freezer alarm light constantly on
1) It could be a short. 2) The thermo sensor that turns the light on could be defective and needs to be replaced.
Mar 24, 2015 | Hoover 9.9 cu. ft. / 280 liter Upright...
Fridge door Magnet does not work
do you mean the door seals,if so you may need new ones or you have lost the vacuum in your ff, they are not magnets they feel like it but it is vacuum sealed,,try a ff second hand shop
Mar 27, 2013 | Kenmore 17.5 cu. ft. Top Freezer...
Change digital thermostat on frigidare freezer
Not hard to do. Just make sure you have it grounded well. Very reliable. Just follow instructions to the tee.
Jan 29, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
Tempt setting
Hi - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Oct 19, 2012 | Frigidaire 16.7 cu. ft. / 473 liter...
Frigidaire freezer always running
Hi Edward - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Oct 13, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Chest freezer lid
Vacuum is caused by contraction of air. If your temperatures are being maintained the difference in how easily the lid opens and closes is not a point to worry about. If the lid wont shut after it is opened you do have a problem. If the lid is staying open at one corner try, with the lid open give it a slight twist pulling on the corner that is not closing fully. This action should spring the lid back to its original sealing position.
Jun 12, 2008 | Freezers
Door seal
i wouldn't worry about vacuum seal. door gaskets contain a low powered magnet around the entire face for "contact" seal, id look into perhaps something placed on one of the shelves or door blocking the door from closing as tightly as you remembered. if you have a problem with that gasket. it would have to be physically ripped and where it didn't make contact you would have an influx of warm air resulting in ice balls forming inside door liner adjacent to seal
Mar 03, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Freezers Logo
173 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
