Question about Panasonic PT-47WX53 47" Rear Projection HDTV
How to fix a red outline to the tv images
I have a panasonic 47wx54j and it seems a mirror is out of line red to be exact. how can i fix?
  • colosal80 Dec 28, 2008
    how do I know which is the non working stk chip?
  • Anonymous Feb 06, 2009
    My red bulb is not alligning properly and I have no idea how to fix it. I tried fixing it with the remote, but that was fruitless.
  • 185 Answers
It's not the mirror as it does all 3 colors and if it where the fault all 3 colors would look goofy.
goto converge section and replace the non working stk chips
Posted on Dec 26, 2008
  • A Schneider Dec 28, 2008
    it will be the chip that has the yoke wire leading to it from the color tube that is giving you the trouble,
    red,green or blue. if you trace it down the path will go to the chip that's faulty. check the resistors in the circuit as well low ohmage resisters should always be changed as well- 20 ohms or less are suspect. this tube is controled by 2 separate chips so you will need to replace them both, i always replsce all 3, clean that old heatshink compound off and us new liberally making sure to torue the chip evenly and gently, also look for a fue that may be blown sometimes a pico fuse (small green) 3-5 amp.
My tv has a arching green tint towards the bottom of the screen that also gives off a double image. I have a Panasonic hdtv 47 in screen model no: PT-47wx54j
Convergence problems. If they can't be fixed from the setting on the menu then the convergence board's IC's are faulty and must be replaced. This is a job for someone who has some electronics experience.
Aug 09, 2010 | Panasonic PT-47X54 47" Rear Projection...
Panasonic tv power button blinks 5 times
Probably the power supply is failing.
Jun 30, 2017 | Panasonic Televison & Video
I have a 61'' Panasonic tv that is showing green and red outlines around the figures on the screen. It originally started as just green outlines. Any ideas on what the problem is would be great. Thanks
The convergence is off. The convergence is basically the assimilation of the image on the screen from the three "guns" behind the screen. There should be a menu option to align the convergence in the image portion of the menu. If this does not fix the issue, then your convergence chip might be on it's last leg.
Oct 23, 2009 | Panasonic Televison & Video
I have a Zenith 65 in. TV model #R65W28 serial #271-33220211. The words are blurry and there is a green outline on images in the picture even if i reduce color to black and white. what can i do to fix it?...
It sounds like the convergence drive circuit has gone bad. When that circuit goes the red, blue and green don't line up properly. Have a repair shop check it out. While they are in there have the shop clean the lenses and mirror.
Oct 16, 2009 | Zenith R65W28 65 in. Rear Projection...
Convergence On Panasonic PT-47WX54j
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
Sep 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX54J 5-blinks between pasues - no audio or video
IC4511 is defective when the led blinks 5 times. that part is unavailable so you will need the entire circuit board.
Jul 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Blue line trouble
Hi Kracka,
Are you able to post a picture of the problem?
It sounds from your description that it might be a 'convergence' problem which is when the red, green and blue parts of the image aren't alligned properly.
Check in your menu to see if there is a convergence setting.
Hope this helps
Andy
Jun 26, 2008 | Panasonic PT-51G41 51 in. Rear Projection...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
139 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
