Question about Yamaha Portable Keyboard
Won't power on
Dear Tech Support,
I just got a Yamaha YPT-210 keyboard for Christmas. It powered on with the power adapter, and lasted about a minute. It shut off and it won't power back on. I tried batteries, but that doesn't work either. Can you please help? Thank you.
Tiresha
    Top Expert:
  • Yamaha Master
  • 57,096 Answers
Sorry but this is not tech support for YAMAHA
Posted on Feb 13, 2018
buffalonyman
  • 1865 Answers
SOURCE: Yamaha YPT310 use of wrong adapter fried fuse won't power up
1200 ma provides more power than the 700 ma, and would not be affected by using it on a device that draws 700 ma. The voltage of the charger makes a difference as well as the polarity of the plug. (if it is dc)
If the 700 ma charger is not working, most likely the 700 ma charger is not working
Posted on Sep 16, 2009
SOURCE: Yamaha PSR-79 keyboard fried fuse
i have the same problem please someone help us.
Posted on Feb 27, 2010
SOURCE: my dgx-220 ypg-225 yamaha keyboard is dead.
If you know how to use a multimeter then I suggest you measure the voltage from your wall adapter plug that you plug into the keyboard. If that has approx. 9Vdc, then take a look at d151 on the power supply board. See if it is passing voltage. Voltage should pass only 1 way. If you have voltage on one side but not the other then the diode it is open and needs replaced. You can find the diode designator on the board next to the diode.
Posted on Mar 24, 2010
  • 5603 Answers
SOURCE: My Yamaha keyboard YPT-210 just
This is likely a problem near the power input jack or the regulator. It requires opening the unit. If you are not electronically adept, best to take it to a shop for repair.
Posted on Dec 30, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a Yamaha keyboard--PSR-E223
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-YPT-220-Music-Keyboards-manual/id/23656ci473/t/2/
#27 on page 11, rear panel.
Posted on Mar 02, 2011
When I turn my yamaha YPT-320 on the panel lights up for 2 seconds then turns of any ideas
MY guess would be one of 2 things.
1) Power adapter faulty
2) Socket where adapter plugs in has a bad solder joint.
Turn on the keyboard and push the plug on the back of the keyboard up ( hold in upright position ) if it doesn't shut down / or alternatively doesn't work investigate solder connections to pcb for the socket. They often fail and break the track on the pcb. Repair as needed
Jan 30, 2015 | Yamaha Music
Http://music.yamaha.com/registration
soy usuario de un teclado yamaha y queria saber si me pueden enviar las partituras de iniciacion al teclado. gracias mi nombre es Pedro Guardia Berrueco. Mi direccion de E.MAIL: pguardia2@gmail.com. el modelo es psr-E223-YPT-220
Jun 05, 2012 | Music
I was hoping to find a free download for a yamaha-ypt-300 keyboard but no luck
Try to search for XG midisongs and karaoke files (song extentions should be .mid and .kar) on the Internet. There are lots of free songs out there!
Jun 22, 2011 | Yamaha YPT-320 Keyboard
My Yamaha keyboard YPT-210 just stopped working one day. It won't turn on with either the AC/DC adapter nor with six fresh AA batteries. Any ideas?
Dec 30, 2010 | Yamaha Music
I need to know the polarity diagram for the ypt-220 so I can use a replacement power tip
The YPT220 is similar to many of the PSR keyboards and will use the same adapter. MOST, like your YPT220, use an adapter with the center pin positive AND are protected by a series diode in the keyboard such that damage will NOT occur if wrong polarity is used. You should use an adapter that provides 10 to 12 volts with positive on the pin and negative on the shell capable of 1 amp (1000ma).
Dec 18, 2010 | Yamaha YPT220 PAK 61 Key Keyboard wAC...
Yamaha keyboard not working
We have a Yamaha keyboard YPT-330 note E and F sharp not working why?
Feb 25, 2010 | Yamaha Music
When I power my ypt-300 the LCD lights up and
Press the FUNCTION button till "Local Control" appears and then select it "On".
It appears this may take quite a bunch of presses to get down to the Local Control option.
Refer to your manual around pages 56 and 57 to see the list you step through. Local Control is about 2/3 the way down page 57.
Refer to 59 for the simple instruction toe set Local Control on or off.
You can get a free download of the manual at:
http://www.yamaha.com/yamahavgn/CDA/ContentDetail/ModelSeriesDetail/0,,CNTID%253D62635%2526CTID%253D205000,00.html
Click on the resources tab to get to the download.
Dec 16, 2009 | Yamaha YPT400 61 Key Portable Keyboard...
Yamaha Portable Keyboard Logo
102 people viewed this question
Top Yamaha Music Experts
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
