Question about Samsung Digimax 4010 Digital Camera
Car locked displayed and cannot be removed.
We have an 128 mb memory card. After the card was full we downloaded the pictures to the computer. When the card was reinserted the camera displayed "card locked' and we cannot change that nor take pictures.
Please help.
Bryce
    Problem Solver:
  • 7 Answers
Look on the front of your memory card for words that say "lock" and it will usually have an arrow beside it. Move the switch over and reinsert your card. It should be able to read it. Kind of like how a floppy disc has a lock, so does a memory card.
Posted on Dec 26, 2008
Memory full on SD card but still space left
FRIST, download the 83 pics u have and save them. your camera may be reading the internal memory. go to setup and change to sd card option. If that doesn't do it, and it's already looking at the SD card. Format the card. NOTE: see first line again!!!
Jul 31, 2012 | Fujifilm Finepix A600 6 3 Mp Digital...
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Video card....
Most cheaper laptops do not include a full-blown graphics board with expensive dedicated graphics memory. Instead, system memory is shared between the CPU and the graphics subsystem.
How much memory actually is reserved for graphics purposes depends on the software you are running. The frame buffer (the memory used to store the pixels on your desktop) is only part of it - games, for example use a lot of memory to store textures and geometry data.
  • Minimum Graphics Memory: 128 MB
    The smallest memory size your system must reserve for CPU/Graphics sharing.
  • Maximum Graphics Memory: 1341 MB
    The largest chunk your system can configure for sharing.
From the DirectX report you can see, it currently uses 27 MB only.
Your laptop lacks the CPU and graphics power to run high demand games anyway, so 128 MB of shared memory should be sufficient. You can configure this to 256 or 512 MB in the BIOS configuration menu, but I doubt it will make any noticeable difference for you.
Feb 07, 2010 | Toshiba Satellite Laptop
I have a Z1015 IS kodak camera and inserted a 128 MB memory card in it. I shot 25 pictures when it told me the card was full. Yet I used the card on a kodak 135 camera and it took over 200 pictures. Am I...
Sounds like you have the picture quality on the Z camera set to a higher setting than on the 135. Higher Quality photos are much larger and will fill up a small 128MB card very quickly. Get a 2GB card.
Jan 02, 2010 | Kodak EasyShare Z1015 IS Digital Camera
No color on my tv
this system requires about 64 MB of system memory and requires CD ROM as a software where we can install it.
128 MB of ddr memory
display support.
  • BIOS compatible with VESA for super VGA
  • DDC1/2b/2b+ monitor support
  • VESA Display Power Management Support
Nov 28, 2009 | ATI RADEON 9200 SE (128 MB) AGP Graphic...
Got an ATI Radeon9200SE graphics card with 128MB but can't seem to be able to access its full memory capacity. installed xabre driver but only 16MB is seen please help
The memory used, depends on the monitor settings as to pixil width and height and color depth. Using a small display setting, results in less memory being used - NOT a fault in the card.
Aug 19, 2009 | ASUS A9200 SE/TD RADEON 9200SE, (128 MB)...
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
EPSON RX600 PRINTER
Below is a chart of memory card capacities that have been tested by Epson. Testing was done before the products were released.
Please use this chart as a general guide line.
MEMORY CARD TYPE MAXIMUM CAPACITY TESTED
Compact Flash 4 GB
Secure Digital 1 GB
Sony Memory Stick 1 GB
MagicGate Memory Stick 128 MB
xD Picture Card 512 MB
Smart Media 128 MB
Any size of card other than that which is indicated above may work, but is not supported or guaranteed.
sorry for this one :(
Apr 18, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
How many photos can be stored on a digital photo frame?
I generally depends upon the size of the picture that you are storing and the memory card that in the digital frame.
eg 128 MB photo frame ,would store close to 10 pictures at 8 megapixel resolution
Apr 14, 2008 | Computers & Internet
Fe170
You can add memory to your camera by purchasing an xd memory card.
Compatible cards
xD-Picture Card (16MB – 1GB)
There are two ways to record the pictures you take with this camera.
Recording pictures to the internal memory
• Pictures are recorded to the internal memory, and when the number of storable still
pictures reaches 0, you must connect the camera to a computer to download the
pictures, and then erase the pictures from the internal memory.
Using an xD-Picture Card (optional)
• Pictures are recorded to the card when inserted in the camera. When the card is
full, you download the pictures to a computer, and then either erase the pictures
from the card or use a new card.
• Pictures are not recorded to the internal memory when a card is inserted in the
camera. Pictures in the internal memory can be copied to the card using the
[BACKUP] function.
g“BACKUP Copying pictures in the internal memory to the card” (P.25)
“The card” (P.60)
Number of storable still pictures and recording length of movies
Still pictures
Movie
• If you use a non-Olympus card or a card used for another application, such as for
a computer, the message [CARD ERROR] is displayed. To use this card with this
camera, use the [FORMAT] function to format the card.
g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
Additional shooting tips and information
Increasing the number of pictures that can be taken
IMAGE QUALITY Image size
Internal memory Card (128 MB)
SHQ 2816 × 2112 2 25
HQ 2816 × 2112 6 76
SQ1 2048 × 1536 8 108
SQ2 640 × 480 60 726
Remaining recording time
HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
Dec 15, 2007 | Olympus FE-170 Digital Camera
Samsung Digimax 4010 Digital Camera Logo
100 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
