Question about Samsung DynaFlat TX-P2775H 27" TV
The sound dies after a while and comes and goes.
Samsung Dynaflat 27" TV. Does it pay to fix? can I fix it myself?
  • myronglucksm Dec 26, 2008
    This may turn out to an excellent suggestion particular since the TV is used by an older person who may find the enhanced sound suggested by the writer to be particularly good. Thanks for the idea.
  • 741 Answers
First unless you are a trained T.V repair man do not attempt to work inside of your T.V. set. The voltage, even when turned off, is enough to kill you. But on the bright side T.V.'s have a sound card just like computers. Check the manufacturers website to see if they have one available for your brand and model. It is cheaper to buy the sound card and then have someone fix it as opposed to having them buy the sound card for you. All you will have to pay is the labor. Hope this helps.
Posted on Dec 25, 2008
    Genius:
  • 2,920 Answers
You can buy a bew tv for the cost of trpairs to that one...id go with a new tv once you have one problem it tells you there will be more problems
  • 10,594 Answers
It depends as if you have prior experience of Tv repair then you can repair it. requires few tools like solder iron, desolder station, multi meter, screw drivers etc.
let me know model number to help you out.
  • 4,472 Answers
It may be worth it to fix it. Could be something as small as a bad soldering connection. Unless you have a lot of ability with electronics most consumers would be unable to fix a problem of this nature. Also most times it isn't worth it to repair. You can go to craigslist.com and find a used replacement for 40-50$ that would most likely be a better tv. Though I would still call a professional or bring it in to a nearby tv service center as It may be a cheap fix and you can get an estimate for quite cheap and know wether it will be worth it or not. Another easy fix, would be to buy a 5.1 surround sound system. You can get them at walmart for as little as 40$ to 60$. Just have your audio go through the stereo instead of your tv. If you need any further assistance please let me know. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
We have a Samsung 27" Dynaflat HD that won't turn on.
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. The question will be, is the part still available? Before paying a TV repair person $75+ to diagnose the problem, ask yourself if you're willing to pay $150 minimum to fix this particular set. Also keep in mind that most TVs that old have a very limited number of replacement parts still available. Normally it will cost at least $75 to have the set looked at by a repair shop (diagnostics). If the part needed to complete the repair isn't available, you won't get that money back.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
Jun 18, 2009 | Samsung DynaFlat TX-P2764 27" TV
Tv pictures suddenly goes dark blue
the tube could be going out. Do you have a warranty on that?
Nov 01, 2008 | Televison & Video
2003 32 inch samsung dynaflat hdtv
Dez,
The ticking indicates a feed back on the power supply - most likely the shutdown circuit itself because something up-circuit is shorted. MY first guess would be the HOT (Horizontal Output Transistor) - Second guess the FBT or Flyback Transformer...
I might have the service manual for that, just email me personally and make it clear what you're after. I get nearly 3000 emails a day and I be real lucky to remember what this is all about when I get the mail...
Bill
premtech@willapabay.org
PS Go online and download Pando... It's a free download and the best way to send large and/or multiple large files over the net...
Jan 29, 2008 | Samsung DynaFlat TX-P2775H 27" TV
If it's not yet a year old it should have some warranty - take it to the shop.. It's probably the HOT (Horizontal Output Transistor) which have been a problem child in this series all the way back to the TXP2745... But don't even crack the case on this one if it's that new - labor might not be covered but parts might. In any event replacing the HOT is not a difficult or expensive job.
Bill
Nov 15, 2007 | Samsung DynaFlat TX-P2775H 27" TV
Watching tv and screen goes black w/no more sound!
you can check only for the fuse if it is busted or not
locate the fuse. check if it open using a tester.......
if you have no experience yet on electronic servicing then you can fix it.
Nov 13, 2007 | RCA TruFlat 27F520T 27" TV
Audio
it is not remote problem please check the following 1 speaker or its wire for loose 2 check supply to sound section 3 check loose contact or loose part or print. 4 check for loose connector 5 check audio ic 6 check for signal to sound section ic is coming. hope this will help.
Oct 01, 2007 | Samsung DynaFlat TX-P2775H 27" TV
Samsung 27" Dynaflat that warps image
the problem is into your power supply try to check you b+. it is a low b+
Apr 28, 2007 | Samsung DynaFlat TX-P2775H 27" TV
Noise Issues with Samsung Dynaflat TX-P3264H
yes ur right that is a flyback that is leaking! it produces a high pitch sound. well if u want to be sure that ur part is genuine. go to the manufacturing authorized service center. for sure they have available part. try also to look into the horizontal cuircuit. there might be something else that was damaged. probably the horizontal output transistor. gud luck
Jan 20, 2007 | Samsung DynaFlat TX-P2775H 27" TV
Samsung DynaFlat TX-P2775H 27" TV Logo
52 people viewed this question
Jerry Greenberg
Jerry Greenberg
