Tecnik TKL9260 Front Load Washer
Problem for Tecnik TKL9260 Front Load Washer
Washer has power but tub won't turn, i can use it, can someone help?
By Bomber - usenet poster
Same Problem
Aug 19, 2008
-   how do you take off the agitator?
-   Guest
Jun 06, 2008
-   Tub won't agitate or spin. Does turn on and the water will fill and drain. The belt is intact. Does not smell burning, but the motor sounds like it's stuggling. Right now I hate this machine and the place where I bought it.-   Guest
May 02, 2008
-   The washing machine races through the cycles
and does not spin at all. We have tried running
the machine with different wash load sizes but
it doesn't make a difference.-   Guest
Mar 16, 2008
-   brake is sticking yall ,, if you turn tub by hand counterclockwise it will release i have torn it down to fix again yet but last time there is a plastic washer on trans bottom side that seems to disolve, contact a repair man that wasnt sleeping thru the training as in the commercials ps model mav7000 same issues-   gborgaro
Mar 09, 2008
-   Have the same problem. The motor smells like it's overheating. The water pump turns freely, the transmission looks fine inside it goes around and the shaft moves back and forth one way and the other when you turn the electric motor by hand. The agitator was moving real slow and then stopped all together and motor smelled. There was a bunch of change under the agitator when I took it apart. Could we have burned up the motor?
Also how freely should the drum turn when everything else is out of the machine?
Thanks,
Dodge-   willdropov
Best Solution
posted on Dec 13, 2007
Very Helpful)
bob 77
Rank: Apprentice
Rating: 100%, 1 votes
This is an old question but probably pops up a lot so here's an answer for anyone searching:
I agree with Bomber, sounds like motor coupler. You can get the part on line at RepairClinic.com.
Tip the washer over on it's right side after taking off the hoses and unplug (of course). Support the top on a footstool (or some object that won't break or slip) so you don't have to lift it off the floor when you raise it. Have a towel or two ready when the hoses start dripping.
Look at the area between the motor and the gear box. If the nylon coupler is broken it will be in pieces.
There is a hose in the way; squeeze the wire clamp and remove the right side of the hose. Catch the water with a towel.
There is a thin metal strap holding the motor against the gear box and secured with a screw. I took off the screw with a small 8mm wrench. the strap then pops right off.
Pull the motor apart from the gear box and remove the two nylon "spiders" and the rubber grommet between them.
Replace with the new parts and reattach the strap and the hoses and your done. Very easy. Don't drop the washer on your foot and you've saved a bundle in repair costs.
Was this helpful?
Yes
No
Solution #2
posted on Dec 21, 2006
Somewhat Helpful)
andiman
Rank: Apprentice
Rating: 80%, 4 votes
check the carbon brushes in motor .there is one on either side.pull them out they should be plastic holders with black chalky things in end(carbon) if one(or both) is dull they need changing
Was this helpful?
Yes
No
Solution #3
posted on Aug 08, 2005
Somewhat Helpful)
Ranny
Rank: Apprentice
Rating: 0%, 0 votes
Motor may be overheated Let washer cool for 30 minutes. If it still won't restart, call a professional.
Was this helpful?
Yes
No
Solution #4
posted on Apr 01, 2007
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Try to see if the washer's electric motor and transmission coupler is broke.
If so you can simply get a new one from your dealer and fix it your self in a bout one hour.
Part is about 15.00 bucks or so
Good luck
Solution #5
posted on Aug 13, 2007
Not Rated)
dovi
Rank: Guru
Rating: 88%, 2496 votes
Be aware you sholkd unplug washer's power cable first !!!!!!
Was this helpful?
Yes
No
Solution #6
Not Rated)
gittos73
Rank: Guru
Rating: 87%, 300 votes
most washer motors have carbon brushes if these are low motor wont turn they will have 1 wire onto them if they are about 8ml and less replace them
Was this helpful?
Yes
No
Solution #7
posted on Apr 13, 2007
Not Rated)
premm
Rank: Guru
Rating: 93%, 3321 votes
Over-loaded? Sometimes it helps when you actually weigh your dirty linen. Try to limit with machine's capacity (which u will find in users'manual)
Was this helpful?
Yes
No
Solution #8
posted on Feb 20, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thank you so much. IT HELPED!
Solution #9
posted on Jan 09, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
1.water not filling due to clogged filter at intake valve pour few mugs of water in detergent case if it starts spinning fault in intake valve.
2. hydraulic switch checks if water is filled or not may be at fault.
3. broken or slipped V belt open rear case to check.
4. circuit board fault
if still not solved call a pro.
Solution #10
posted on Jan 07, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If motor seems to start to work then gives up, try looking at the rear of the motor. There is a magnet screwed into the shaft. This spins inside a sensor that tells the controller how fast the motor is running. The magnet slowly unscrews itself so does not sping with the motor shaft. The contro unit then thinks the motor or drum is stuck so turns off the motor power.
Solution, prize off the sensor from end of motor and screw magnet back into shaft. For a better fix use some threadlock to stop it happening again.
Hope this helps - worked twice for me - hence use of threadlock now.
Mat
Popular Solutions for Tecnik TKL9260 Front Load
Questions and Unsolved Problems for Tecnik TKL9260 Front Load
Do you recommend Tecnik TKL9260 Front Load Washer?
Answer
Answer
My washing machine won't drain. Its a top loading old maytag.
Answer
My KitchenAid washer won't drain water it just keeps spinning
Answer
my washing machine works fine but when it has finished i open the door and its full of water, what... (More)
Answer
does not wring out clothes in spin cycle need to run through spin cycle twice and they are still... (More)
8 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 11, 2008
Same problem. Sounds like it's turning just like normal, but it's not turning. No funny smells or anything.
Comment by Taloxz, posted on Jan 03, 2008
when I turn on my washing machine, the twister device not moveing, and an smell of plastic-insulate wire perhaps starting to expulse burn smell obligating me to took off the energy cable out from the wall electric connector.
Comment by Gamini, posted on Dec 15, 2007
Model RRL580466
There is no water block
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Tecnik TKL9260 Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
