Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Cannot set screen width
New 42" HD Regza HD flat screen.  Cannot get correct width.  With HD cable box/cables,  using natural/native gives channel logos slightly off screen and sports channel lacking score boxes on left.  Seems too wide. Cable Co says their box set properly and is due to a TV setting, but thought I tried them all.
  • Anonymous May 19, 2009
    the screen is too big..both width and hight...went throught the settings but no luck
    Sniper:
  • 105 Answers
Both the TV and the Cable box have Aspect(height/width) settings. You must confirme the setting on the cable box and then do the TV.
1. Set TV to Native, this should show image exactly as the cable box sends it.
2. change Aspect settings on the cable box until you get one that works
3. if you get a good one, then your OK. You will just need to find a setting between the 2 devices that work for you. Also, these settings may change automatically for the TV or cable box based on the channel
Posted on May 21, 2009
What is the best converter box to use with toshiba regza 42hl67 flat screen tv?
As far as I can make out, this Toshiba model is made for the US market so doesn't actually have a freeview tuner. It will only receive satellite and cable HD signals and local US TV, all of which has to be bought. You need to get something like an August DVB400 - HD Freeview Set Top Box -Digital PVR Tuner with USB TV Recording, eBay would be best I think, where they are sold for under £30.00. The tuner packed up on my 32" Regza so I bought one of these and it works fine. Plus you can record to a USB stick if you don't want to miss a programme. Hope this helps ......BS
Feb 22, 2015 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Regza 42"
ok...so do you want to work this out? the user manual speaks to this...
Jun 03, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
42 in hd flat screen
If your TV was "Built" prior to November 2006 it does Not have a Digital tuner and you need a converter box (if you are using an off-air antenna) Hope this helps
Jul 07, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Changing TV set up to cable from "air"
Try setting tv to channel 3 or channel 4, this should coincide with the back of satellite box (a little black switch with a 3 or 4). then switch channels with your satellite box. I would recommend using another output off the satellite box to feed the other tv, a splitter loses some signal quality an can go bad as well. get a long rca cable to feed tv!
Mar 01, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Cannot optimize picture width on new flat screen HD
On your cable box remote press the hd zoom button. I have comcast cable box and it worked for me.
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
No Video for my cable tv. Audio works
You have the TV connected to the cable box with an HDMI cable, I'll bet. The problem is with the cable box. If you unplug the cable box and plug it back it it will reboot and proabably work. You should connect the cable box to the TV using component cables and you won't have this problem again.
Nov 11, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Red Vertical Burn Line on LCD Screen
Try changing the picture setting on the television rather than from the picture box.
Sep 09, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Vertival Color Lines
We had the same thing happen to us on the right-hand side. A technician told us yesterday that the Motorola Cable Box (supplied by Shaw Cable) places a border on Non-True HD Channels. Because we didn't place our picture setting to 'full-screen' each time we viewed these channels and burn line was created. He gestimated a replacement screen runs about $800.00 Canadian, but we have a 3 year extended warranty and will receive a new TV. He also said it happens on all big screen tv's that use a cable box creating borders on Non-True HD Channels.
May 04, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
160 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
