Question about HP OmniBook 500 Notebook
Disc drive ejecting
I have a drive thats decided to just eject itself without a disc in it,it only stays in when the laptop is off or if a disc is running.Got some advice.
  • Melanie Chappelow Apr 17, 2007
    Thanks but i already went to fixya support i am baffled..
OK no worries but it worked,thank you very much,we are very computer wary.You saved the day thanks mel
Posted on Apr 24, 2007
    President:
  • 2,961 Answers
See:- http://www.fixya.com/support/t143066-disc_drive_trouble
Posted on Apr 16, 2007
  • andrew pester
    andrew pester Apr 17, 2007
    This is because you posted twice and i answered on the other post to which i put the link
How do you force eject a disc from a macbook pro?
Five ways to eject a stuck CD or DVD from the optical drive
Ejecting the stuck disc can usually be done in one of the following ways:
1. Restart the computer and after the chime press and hold down the left mouse button until the disc ejects.
2. Press the Eject button on your keyboard.
3. Click on the Eject button in the menubar.
4. Press COMMAND-E.
5. If none of the above work try this: Open the Terminal application in your Utilities folder. At the prompt enter or paste the following:
/usr/bin/drutil eject
If this fails then try this:
Boot the computer into Single-user Mode. At the prompt enter the same command as used above. To restart the computer enter "reboot" at the prompt without quotes.
Regards,
Alex
Aug 14, 2014 | Apple MacBook Pro Laptop Computer with...
Dvd disc
Hi There,
Try holding down the 'mouse' bar (i.e., The clicker below the track pad, or the track-pad itself if you don't have the 'bar') when you are starting up the laptop. This will usually eject disks in the optical drive.
If that doesn't work, and dragging the disk icon to the trash doesn't eject the disk, then you probably have an issue with the drive itself.
Take a look at ifixit.com for guides on removing the optical drive and opening the drive to get the disk out.
Hope this helps & good luck!
Apr 21, 2014 | Computers & Internet
Screen is grey and keyboard wont respond.
4. Press COMMAND-E.
Jan 25, 2013 | Apple Computers & Internet
I can't open my disc drive on my Acer Aspire 5820T without using a pin. How do I get the eject button to work?
I suggest that you can use the other method to eject: press start and go to my computer, select the disk drive and you should see an eject option in the menu bar.Remember that disk drives are subject to computer admin and do not respond quickly to a button press, especially if a disk process in taking place...
Mar 03, 2012 | Acer Aspire TimelineX 5820T-5951 Notebook
My hp laptop keeps ejecting disc itself when i insert any disc. Wat do i do pls
> keep ejecting
The disk-drive is having a mechanical problem, i.e., it is not fully-loading the disk,
or it is not detecting that the disk is fully-loaded. Therefore, it assumes that the open/close
mechanism is "jammed", and so it ejects, to indicate that the disk-loading was not completed.
Replace the disk-drive.
Jun 26, 2011 | HP Computers & Internet
I'm having problems ejecting cd's from laptop after they're done burning.
Hi
If you go into the computer and open it look for the cd/dvd drive
highlight and right click it and go down to the properties
now click on recording up in the top right hand side of that box
then go down to and put a tick in the box where it says
Automatically eject the disc after a master burn then restart the laptop
this should then automatically eject after a burn
if it don't then
click on your computer icon
it should open it up and show you your hard drive/s
also the cd/dvd drives
if you highlight the cd/dvd drive then right click it and go down to eject hopefully this will eject it
also there is a small pin hole just beneath the push eject switch on the drive itself if you push something thin in there gently but firmly it should also eject the drive
hope this has helped you
please let us know if fixya has fixed it for ya
Jan 30, 2011 | Dell Inspiron 1545 Laptop
My PC won't allow me to right click to choose the eject option for a CD. I want to know if there is a way to remove the CD manually.
The DVD drive itself has a small horizontal 'eject' button that you can press to eject the disc.
If the button fails the disc is stuck however the DVD drive will have a small hole near the eject button- about 2mm in diameter. Straighten a paperclip or similar and push into the hole until the disc drive mechanism releases and opens.
Thanks,
Javaftper
Aug 07, 2010 | Dell XPS M1330 Notebook
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
HP OmniBook 500 Notebook Logo
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
