Question about Magic (ED8000) Professional Microphone
ED 8000 Can you help... we are at sea and need the above mic for Kareoke... The Mic hasn't worked for a few weeks and 4 people have de soldered it and generally mucked about with it... If I touch the 2 lead wires it hums so I know its the connection to the mic head... My problem is the contacts on the mic head I found a white wire off... and the Filipino guys said someone tried to fix it... My question is that the mic head has 2 connections either side of the Mic and obvious points to apply the wires opposite each other.... On closer inspection I recon that on one side The black wire contact appears to be bridging (now filled with solder) 2 contacts. Basically do the 2 wires oppose each other or are they adjacent on the same side of the ED 8000 mike sensor.. Do you have any wiring diagrams to assist... TY for being there... doing this to keep Moral up on ship Regards Mark Wootton Deep Pioneer Lagos Waters West Africa
    New Friend:
  • 18 Answers
You need to replaced the "voice coil". that thing that youve been desoldering and soldering is the voice coil. It has two wires- white and black. it is already grounded and need to be replace (the fact that it humms..). my company distribute wow magic sing here in Philippines and we can easily repair that.
Posted on Mar 09, 2009
Repair centers for ed2000
Before starting to search for a replacement board do the following steps:
1-take out the batteries.
2-wash your board with water and a little detergent using a tooth brush.
3- use a hair dryer to dry your board .
4- leave your board in a warm place(preferably in sunshine) for a few days to make sure that no moisture is left on the board.
After you have done all this you may find your mic working normally .If your mic is still not working ,using a magnifying glass search for loose solder joints.
hope this helps you.
Sep 06, 2012 | Magic Sing Along Consumer Microphone
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
My ed 8000 mic cable is working on and off...do think the cable is bad and where shoud i send it for repair?
Hi, I think a local musical instrument store may provide the most inexpensive. Someplace such as Guitar World or someplace similar. I would think you shouldn't have to pay more than fifty dollars to get it fixed. Good luck, I hope I was helpful-please comment back as I need some votes to boost rank and THANK YOU for choosing FixYa, Prodzilla
Apr 24, 2011 | Magic (ED8000) Professional Microphone
I have a galaxy dx55v radio in my truck. When i pick up the mic to talk someitmes it works and sometimes it doens't. Have tried different mics with no help. Have taken it to a tech and they changed a...
Hi cb,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
You will need a soldering iron for this. First, remove the cover from the radio.
You will need to check where the mic plugs in the circuit board, check for
loose connection in solder joints, just re-solder this area and you should
be good to go. I hope you find this solution helpful.
Thanks for choosing FixYa.
John
Jan 18, 2011 | Galaxy Radios DX-55V Base CB Radio
SAMSUNG JET 8000 I CAN HEAR MYSELF IN MY EARPIECE BUT THE OTHER PERSON CANNOT HEAR ME...DOES IT NEED GO IN SHOP 4 REPAIR???????? THNX
Mic problem,Yeah u need to visit a mobile shop they will repair and give u the parts are minor so.Cost will be less.
Jul 13, 2010 | Samsung Jet S8000 Cell Phone
Mic to PC
This mic is a condenser type microphone. It needs phantom power (48v) to operate. Might want to buy a USB mic preamplifier box, like an M-Audio product, which will provide phantom power, xlr/1/4 inch inputs and USB output.
May 23, 2010 | Behringer C-3 Professional Microphone
Logitech QuikCam Express...Problem
instalador de camara
como tieneque bagar el listalador de camara
May 07, 2008 | Logitech QuickCam Messenger Web Camera
Cant talk through mic
Sounds like a bad or miswired mic. Try a new mic ( use the proper cobra mic ). If the problem still continues, check all the swiches on the front of the radio and make sure you don't have any cold solder joints ( broken lead to board connections ). Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 19, 2007 | Cobra 29 WX NW ST 40-Channels Base CB...
No sound
The Cobra 25 requires the mic to be working for any sound to come out. My suggestion is that you first try a new mic. If this doesn't work, look real close at the board on the soldered side ( around the if section, thats the area that right under the waxed area on the component side of the board ) for cold solder joints ( broken lead solder) You may need a magnifing glass. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 17, 2007 | Cobra 25 LTD 40-Channels Base CB Radio
Magic (ED8000) Professional Microphone Logo
409 people viewed this question
Top Magic Audio Players & Recorders Experts
conquer111
Level 1 Expert
Barbat Nae
Barbat Nae
T-Comtech Repairs
T-Comtech Repairs
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
