Question about SanDisk Sansa Clip MP3 Player
Can't turn on sansa clip. it will turn on if connected to a pc
  • mer_327 Dec 25, 2008
    it turns on some times. but when i try to delete a song it shuts off and won't come back on
  • 8,596 Answers
This player goes to sleep very fast. If it does, just press the center button to wake it back up.
Posted on Jan 01, 2009
My player got hanged.and its not functioning? what probably the cause and how can i deal with it? it cannot be turned off..the menus are not functioning
Hi,you need to rest your mp3 player...
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Instructions
Complete Reset
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
Instructions
Complete Reset
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
How do I charge my Sansa Clip - I've lost the instructions
When I turn on I get a message stating FAT is corrupted please connect to pc. I have connected to pc and nothing happens. Please help
Jan 09, 2011 | SanDisk Sansa Clip MP3 Player
I turned the device off while the hold switch was on. Now it will not turn on. It just displays "fat is corrupted. Please connect to pc and" and then shuts off.
I have this same problem. So I connected my Sansa Clip to my computer, and my computer won't recognize the device, when before it would. Any fixes out there?
Jun 15, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Clip won't work. When I turn it on it says: Not enough space for music DB Please free 30 MB. But when i connect it to my computer it doesn't register. PLEASE HELP ME
Because you drag 7 drop songs or files too much into the sansa clip in MSC mode, it causes like that.
Turn it on, it will show " Not enough.....free 30 MB", and then automatically turn off. Plug it into pc, open my computer, it will be under name "Sansa clip..." or "removable disk ". If your pc does not recognize it, unplug again and replug it.
Open Sansa Clip..., or removable disk, and delete some songs.
Good luck
Apr 30, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip on turn on
can u more specific? u mean how to turn on your sansa clip or your clip can't turn on?
if the first one:
u may can see the instructions.
if the second one:
SOLUTION 1 - Reset the player.
SOLUTION 2
- Make sure the player is fully charged.
1. Connect the player to the PC.
2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, then connect it to the PC.
3. Leave the player connected for approximately 2 hours to charge.
4. Disconnect the player from the PC.
5. Verify if you can turn on the player.
6. Reset the player if necessary.
Feb 25, 2010 | SanDisk Sansa Clip MP3 Player
I left my Sansa Clip MP3 Player plugged in while putting my laptop into hibernation. Now player does not response, I can't turn it on, and laptop doesn't recognize it at all.
    Complete Reset of Sansa Clip
  1. Step 1 Turn Sansa Clip on. Press the "Menu" (Home) button on the Sansa Clip.
  2. Step 2 Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
  3. Step 3 Scroll down to "Reset All," and select. You will be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow steps 4 and 5.
  4. Step 4 In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm if you wish to format. Select "Yes."
  5. Step 5 Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
  6. Resetting a Frozen Sansa Clip
  7. Step 1 Unfreeze a frozen Sansa Clip by pushing the power button up and holding it for 20 seconds. Release it, and then turn it on again.
  8. Step 2 Go to the Sansa website and download the "Sansa Firmware Updater."
  9. Step 3 Select "Run" when the updater installs. (Installation will take less than two minutes.)
  10. Step 4 Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
  11. Step 5 Connect the Sansa Clip and then remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Aug 22, 2009 | SanDisk Sansa Clip MP3 Player
My player will not turn on and all my files are empty
Are you using a Mac or PC?
If using PC, then try formatting your sansa clip. This will erase all the files on your mp3 player, but at least you'll be able to access it again. To format: Connect your player, go to "My computer", find your sansa clip in the list, then right click on the sansa clip drive. Click on "Format". Let it erase all your files.. then it should work! I had the same problem, and I got mine to work like this.
If you have a Mac, your computer might not be formatting it properly... try this:
If you have access to Windows, connect your player, launch WindowsMedia Player, and you'll be able to format it correctly...
See the sansa forum for more info: http://www.sansacommunity.com/forum/thread/11585/Sansa-Clip-not-working-anymore/
Good luck...Hope this helps!
May 19, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip 2gb lockec
First of all, may I ask if you have a mini disc player or a Sansa Clip? Because the Sansa Clip does not play discs of any kind.
If you do indeed have a Sansa Clip you will find the FAQ rather helpful here - http://www.sansa.com/support/sansa_clip/faqs
Question 9 there is regarding devices not recognized by the PC and the solutions are as follows:
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If that didn’t help, and you are running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – If that didn’t help, download and Install the MTP Porting Kit (click here)
SOLUTION 4 – If that didn’t help, try connecting the device to the PC using MSC mode
Clip: Go to Settings > USB mode & choose MSC
If none of the solutions work for you, please post the results of your attempts and we can go from there.
Dec 27, 2008 | Audio Players & Recorders
Keeps saying unscribed connect to pc - Its connected!
Uninstall all Sansa software, reinstall it either from the CD or from Sandisk's website, and then replug the Sansa into the computer.
Nov 11, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip not coming on
try turning it o while its on the computer
May 30, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
