Question about JVC THC3 Home Theater System System
Color Gone Set up my JVC TH C3 home theatre system and my dvd's are playing in black and white. Audio and picture are fine but there is no color. Any suggestions as to how to troublshoot? Thanks!
    Genius:
  • 1,074 Answers
Check and see if your dvd player is not on pal if it is then you switch to ntsc.if it is not on pal then check all your connections if every thing is okay its time to call in the tech the dvd is having a problem in the video circuit.good luck.
Posted on Apr 16, 2007
Why wont play color
TH-M505 can display in black in white if connected iimproperly using COMPONENT connections or if cables have gone bad. Try replacing component or changing connection to COMPOSITE. Does it play in black in white using COMPOSITE?
Jul 26, 2014 | JVC TH-M505 System
My disks won't play in color just black and white what's wrong, this works with all color DVD's
If you're using component video cables check them all for good connection.
Jan 17, 2010 | JVC TH-C3 System
Listen to DTV DVR output on TH-C3
im not familiar with this model. can i assume it is a small home theatre system with limited inputs?
in that case, the best thing to do is to feed all your devices...cable, dvr, dvd, etc....into the tv.(audio and video). then use the audio output of the tv to the input on the receiver. you may have to go into the tv menu and set the audio output to the speakers in the tv to fixed mode for a constant level out to the receiver.
good luck
Dec 08, 2009 | JVC TH-C3 System
Panaonic Home Theatre DVD system only plays movies inblack white
Check the region and picture settings on the home theatre's dvd player, it could be set to put out a component signal, or it could be set to a PAL region rather than NTSC
Jul 06, 2009 | Audio Players & Recorders
My dvd theater system has no color
some times the dvd's change by itself to PAL/NTSC system so you need enter to set up and select the option in system tv NTSC for America users. Make shure conect yellow cable in the yellow conector.
May 25, 2009 | JVC TH-C5 System
TROUBLE SHOOTING JVC DVD PLAYER DOES NOT SHOW COLOR PICTURE
Press and hole Scan Mode button for 2 seconds, Y/C will show in front display, use > to change to RGB then press OK.
Feb 25, 2009 | JVC TH-S11 Theater System
WHEN DVD IS PLAYED THE PICTURE IS BLACK AND WHITE
you was right it was a mix up of my connection`s thank you
Sep 27, 2008 | JVC TH-M505 System
JVC TH-S3 System
try to check the av output wire if its properly connected according to its color.
Jul 20, 2008 | JVC TH-S3 System
Black and white picture on the JVC TH-505
If you hold the VFP button while a movie is on, you will get a small box on the corner that shows your color. My default color also turned black and white. I just moved over to a user1 color setting (push the right arrow on your remote), and it allows to the change the colors. You might be able to put the colors to come out through here. Hope this helps.
Jan 28, 2007 | JVC TH-M505 System
121 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
