Question about Acer Aspire 5500 5570-2609 Laptop
Not able to connect wireless
I am unable to connect to the wireless network.
I am using presario CQ56 notebook PC, it see all available wireless network but windows was unable to connect. please what should i do?
Most wireless networks are secured. If you do not have the security passkey for the network you are trying to connect to, Windows will be unable to connect. Even some free wireless hot spots require you to get the password from the staff in order to connect. Passwords are case sensitive as well.
Dec 15, 2015 | Computers & Internet
Cannot switch on wireless connection Packard bell laptop does not have switch
Wireless problems with a Packard Bell PC or laptop can be caused by a variety of issues.
The best troubleshooting resources are the documentation that came supplied with the computer, and the Support section of the Packard Bell website.
Unable To Detect Wireless Network
If the Packard Bell machine is unable to detect a wireless network, the computer itself or the network could be at fault.
Check that a wireless signal is being broadcast via another PC or device, and check that are wireless adapter is installed, complete with the latest drivers, which are available at the Packard Bell website.
Unreliable Wireless Network
If the wireless connection is unreliable, intermittent or very slow, it suggests a problem with the Wi-Fi broadcast.
Try positioning the computer closer to the router broadcasting the wireless signal, or use a signal booster to improve the range.
Download and install the latest driver updates from the Packard Bell website and through the Windows Update tool.
Unable To Connect To Wireless Network
If the computer can detect the network but is unable to connect to it, a network security key may be required. This should have been configured by the person who set up the network. Consult the documentation that came with your router for details of how to change it or generate a new key.
Hope this helps
Oct 23, 2012 | Packard Bell Computers & Internet
No enternet access
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire.
Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver.
Restarting the computer corrects this issue.
hope this helps
Sep 26, 2012 | Linksys Wirless Router Wrt54gs V7 Router...
Acer Aspire 5733 Wireless connection lost
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
Sony SMP N200 Network Media Player - unable to connect to home wireless network
You may need to enter the SSID in the wireless configuration in the Sony.
Check the Netgear wireless setting ie. the SSID, WPA or WPA2 encryption key, then apply these settings to the Sony wireless card settings.
Mar 20, 2012 | Computers & Internet
Unable to connect to Wireless Network Connection (DELL D600)
could you open the command prompt and type ipconfig and tell me what you get..
Oct 08, 2009 | Dell Latitude D600 Notebook
Unable to connect to wireless internet. wireless connection shows disabled.
check whether wireless drivers are installed.
check wireless is enabled.
check in network connections whether u can c wirelass lan connection.
Apr 21, 2009 | Computers & Internet
Unable to connect to wireless network
Re-Enter your wireless key correctly is normally what thats means
Mar 15, 2009 | NetGear WG311T 802.11g/b Wireless Adapter
Unable to setup wireless network
you will need to search the wireless networks again as the old settings will still be assigned to the wireless card.
So refresh the list of networks and then click on your network to connect.
Oct 14, 2007 | Edimax 4 Port Wireless AP Broadband Router...
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
