Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Dim display monitor
My envision lcd monitor is dim display.can't adjust the controls on the monitor to correct the problem
  • 298 Answers
Scan rate off the charts?
My guess.. Your PC is overdriving the monitor and it is protecting itself from harm.
Startin SAFE mode (press F8 wile booting) and SAFE mode to see if it worksin Windows DEFAULT setting. Then Reboot and readjust to somethingsensible (1280*1600, 32bit, 60Hz)
My guess is that MSoft pushed a patch or SP to your box and IT replaced the dll your monitor was using.
Goto mfg and DL and reinstall the correct drivers again, If this doesn't fix it, then the LCD inverter and Tube are on the way out. You can get parts to fix that here:
LCD Repair and Cable parts
Universal LCD and Inverter Parts
Good Luck!
Posted on Mar 26, 2009
Had been taking several attempts to get it to come on. Sometimes had to unplug and retry. Now only says "Scan TV". Is repair likely to be more expensive that what set is worth?
Sometimes heat is a real big issue with LCD monitors, over time it causes fractures and circuit breaking in the chips and pops off a few capacitors. It is likely that your control board has a couple bad capacitors and/or components that have failed yet have not removed the display capacity. So your T-Con board is likely not the issue.
When searching online use your monitors make model and production date and include "Main Control Board" so you can find products that are for your unit.
Searching Ebay and Amazon are common places these units will be sold and run anywhere from 5$ to 200$ depending on your monitors grade.
Source:
http://www.ebay.com/sch/i.html?_odkw=Envision+driver+control+board&_from=R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XEnvision+main+control+board.TRS0&_nkw=Envision+main+control+board&ghostText=&_sacat=0
Mar 06, 2015 | Envision 19" Widescreen Flat Panel LCD...
What can I do to fix dim display screen on my elna 9006
There may be an adjustment on the backlight display?
Do you have an Elna 9006 Envision manual?
Feb 16, 2015 | Elna Sewing Machines
Screen Resolution Error Message
go to control panel look up display adjust it ok;
Apr 30, 2010 | Envision 19" Widescreen Flat Panel LCD...
Envision 19" widescreen
You can go to the Envision customer support website and look for the driver under the driver support section for you model monitor. The website is. www.envisiondisplay.com. You can also call the Envision customer support at this telephone number. !-888-838-6388. They should be able to help you with getting the correct driver to support your set-up. I hope this information helps you with your problem.
Dec 27, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Envision 17inch lcd Monitor problem
This problem is a failing of the backlight circuits. the lamp is either failing or the power circuit is failing, causing the lamp to dim down it power output. Return to dealer for service. Hope this helps you.
Dec 17, 2008 | Envision EN-7100e 17" Flat Panel LCD...
All pictures appear wider than they really are
You may have to match up the video card settings with the monitor settings to get the correct resolution setting. Try adjusting the resolution of the graphics card to match the setting for the monitor. If this does not work you can call, Envision customer support at this telephone number : 1-888-838-6388. They should be able to help you get the correct setting for you set-up. I hope this information helps you with your problem.
Dec 03, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Screen shift
Try setting the refresh rate to 60 Hz. (Maybe 75).
Is it xp?
Right click an empty part of the screen, properties, under monitor (I think; I'm on Vista) you can choose the refresh rate.
Most LCD's should be at 60 Hz.
Jul 04, 2008 | Envision EN9410 19" Flat Panel LCD Monitor
Envision LCD EN-7100e Monitor "Input not supported
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision EN 7100si LCD 17" flat screen
First try auto-adjust with the auto button on the screen
if not worked
Make sure she installed the envision driver. I jus saw it's a discontinued product. Also this product has a maximum resolution of 1280 x 1024.
If installed check her resolution. Right mouse click on desktop>properties>screen. Try alternate resolutions and see what happens but don't set it higher then 1280 x 1024 if possible.
Nov 28, 2007 | Envision EN-7100e 17" Flat Panel LCD...
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
144 people viewed this question
Top Envision Computers & Internet Experts
Paul Bade
Mark Gough
Jim Goldsmith
Jim Goldsmith
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
