Question about Sony KV-27FS17 27" TV
Picture Color I have a Sony TV Model KV-36FS10 and when it is first turned on there is a green tint to the picture and after some time the color seems to normalize somewhat but the different picture settings can really look worst than they should i.g vivid, sports, movie etc.
    Problem Solver:
  • 18 Answers
On which side
Posted on Dec 26, 2008
1) I have a Sony KV-32FS13 that has a green tint in the picture. Does any oneknow how to access the service menu for this model? I tried other adjustments and I can't get rid of the annoying green...
Code 5 is "AKB error". AKB, or auto kine bias, is a cicuit that monitors the three color guns of the picture tube (red, green and blue) and tries to adjust them for proper color balance. If it can't, the picture is blanked (usually) and the timer/standby light blinks 5 times. When the color drives aren't balanced, you see a color tint in the picture like you're describing.
There might be a problem in the AKB circuit, or the picture tube may just be old enough that the AKB circuit has run out of adjustment range. If the tube is at fault, you should consider replacing the set. A new tube will cost nearly as much as a new 32-inch LCD TV, and you'll need to pay someone to install it and set it up. There are special tools required to perform the convergence which gets the color guns aligned with the face of the tube so they hit the right colors.
If you'd like to try tinkering with the service menu adjustments, this site explains how to access the menu and gives a list of settings.
Jan 02, 2011 | Sony KV-32FS13 TV
The picture has a green tint to it on all channels
The color signal consists of Red, Green and Blue. Those three colors, at various degrees, make all the other colors on your screen.
If you have a BRIGHT green screen it's best you don't operate your set.
If it's just tinted green then there is a problem on the CRT (Cathode Ray Tube) drive board. Do check your "tint" setting and see if someone misadjusted it. If that isn't it then you need to have your set on an electronics bench and get an estimate for repair.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Green tint and psychedelic color swirls in picture
I have a good but with green tint on a polaroid tv model number 64SX505Y-DC02
Dec 28, 2008 | Polaroid FLM-3232 Television
KV-32FS120 makes a loud noise and green tint when turned on
Loud noise is possibly made by Degausing Coil to demagnetize picture tube and its normal.
Green tint shows picture tube is bit weak in electron emission due to its age and takes time to present good white balance result (good colors)
Sep 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Jun 15, 2008 | Sony KV-36FS100 36" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Trinitron KV-32XBR37
This may be a bad crt or picture tube. Take a good look at the picture when it's on and see if it has a pinkish or greenish tint. This is easiest to see if you turn the color adjustment all the way down. If it looks like the tint is green or pink and the focus isn't great then it's probably a bad crt. Not worth repairing if its the tube.
Jan 04, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Blurry Images
Hello paulaspec,
You have a problem with the three factors, and they are screen voltage, focus voltage, and control (focus 2) voltage. Basically these voltages have to be adjusted since the components in this section have aged some. These controls are usually located in the television on the IHVT (Integrated High Voltage Transformer) or as it is also called the flyback transformer. these controls must be adjusted together, along with the color controls. Here is how the adjustment is done (You will need a schematic diagram, a DC volt meter, and a color bar generator to do these measurments):
1) turn color and tint fully counter clockwise until you have a black and white picture.
2) connect the color bar generator to the TV (ch 3) and turn it on, you should see bars in various shades of gray
3) adjust as best as possible the color and tint controls to obtain the color bars on the screen Red Green Blue.
4) measure the voltages on the focus, screen and control grids of the CRT and match them to the schematic digram measurements.
5) adjust the focus screen and control grids to match the ones on the schematic diagram
6) once this is done then you adjust the color controls once again to obtain the red green and blue bars on the TV screen.
This should help if the CRT (picture tube) electron guns are still good and if the flyback transformer voltage supply is working.
However if you do not have a background in electronics please take the TV to a shop for repairs.
I hope this helps,
Thank you,
Shuttle83
Oct 16, 2007 | Sony KV-20M20 20" TV
Sony KV-27FS17 27" TV Logo
96 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
