Question about Lexmark X4270 All-In-One InkJet Printer
Printer only prints one page of multiple page document
My lexmark X5400 printer just starting printing one page of a multiple page document. I have not tried to print from micro soft word, but when trying to print from the internet the printer will not print past page one.
  • Anonymous Mar 23, 2014
    The automatic document feeder is taking multiple pages at a time during the aligning cartridge process
I dont know how to conect lexmark printer X4250 to my computer
Posted on Dec 25, 2008
2 Suggested Answers
  • 14 Answers
SOURCE: printer only prints one page of multiple page document
hi..
You may try to change the spool data format:
1. Click on "Start," "Control Panel," "Printers and Other Hardware" and "Printers and Faxes."
("Start," "Control Panel," "Hardware and Sound" and "Printers" for Vista...)
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark *** series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Try printing again.
Posted on Apr 24, 2009
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
Lexmark 5400 series printer won't grab paper for printing
Whenever the printer doesn't pulls the paper please pull the pack of papers, browse through the papers with your finger and put them back gently.If it doesn't work it means the wheels that pull the paper are worn and you need to replace them.
For the second problem, this is not a printer problem but a software problem, please specify which software do you use so we can help you, as each software has individual options to print multiple pages. It will also be more logical to post the problem in the specific software area.
Good luck,
GetAFix99
Nov 17, 2009 | Office Equipment & Supplies
My lexmark x6650 is giving me a "cannot retrieve application list" error when i try to scan from my mac. what does this mean? what do i do? jim
You have to Open System Preferences > Print and Fax > Options and Supplies > Driver > Print Using : select a driver to use - select Generic PCL LaserPrinter > OK
Now You can try printing a document using the faulty application, immediately after hitting Print pause the printing in the printer queue (use the printer icon which has now appeared in the dock). With this panel open hit Info > Driver > Print Using : +select a driver to use+- select your printers driver eg.Lexmark x5400 > OK > Resume
The document should now print as normal
Oct 11, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printing errors
Try printing one page at a time and see what happens. Repost!!
Jun 15, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Printer will not print multiple copies
go to start menu, control panel, printers and faxes, right click your printer, click properties, click the advanced tab and make sure your printer is set to spool print documents.
May 29, 2009 | Lexmark X2600 InkJet Printer
hi..
Apr 24, 2009 | Lexmark P4350 All-In-One InkJet Printer
Lexmark won't print whole document
Seems an unlikely solution, but I upgraded from Office 2003 to Office 2007.
As soon as I did this, I was able to print multi page documents. Go figure!
Apr 09, 2009 | Lexmark X4250 All-In-One InkJet Printer
Wont allow me to print
my lexmark x5400 series model number 4425-004 and i can't print from my laptop. Help it won;t recognize the lexmark
Nov 02, 2008 | Office Equipment & Supplies
Printer multiple page document
Try this only for windows user:
To resolve this, do the following :
  1. Windows 2000: Go to Start, Settings, Printers.
    Windows XP: Go to Start, Control Panels, Printers and Faxes.
  2. Right click on the printer icon and select Properties.
  3. Click the Advanced tab.
  4. Click the Print processor tab. The Print Processor screen appears.
  5. Change the Print Processor to Winprint and change the Default data type to RAW .
  6. Click OK in the Print processor screen.
  7. Click Apply, then OK.
Apr 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
Print multiple pages
check your printer settings, so that it's shows all, and then...
no worries..start by getting new driver for that here
Feb 18, 2008 | Lexmark Z1420 Printer
Lexmark X4270 All-In-One InkJet Printer Logo
297 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
