Question about Panasonic TC-32LX50 32 in. HD-Ready LCD Television
No video I have a Panasonic TC-32LX50 and the Video just quit. Audio still works fine however the video will not work on the TV or any video inputs. A service technician came out and did not do anything other that try and turn it on and said it was still under warranty and should be replaced. I was given a new one and then told to just keep the broken one. I figure if I could fix this one then I would have two. Is it worth a shot?
    Genius:
  • 1,074 Answers
Yea since the tv was replaced you can call the same technician and let him repair the tv the problem is in the video section or related circuit.good luck.
Posted on Apr 16, 2007
Panasonic TV, TC-P50S2.Yamaha DVD Player DV-C6280.Yamaha Receiver HTR-5450.DVD audio working fine thru receiver. Not sure where to place white/yellow cords to get video feed.
Hello. Usually when you mention white and yellow, there should be a red also, the red and white are right and left audio and the yellow is the video. The audio should be connected to the receiver, and if the receiver has video inputs and outputs, that should be connected to the same receiver input as well, but if the receiver doesn't have video capability, the yellow should be connected to the TV video input. I hope that helps.
Aug 01, 2016 | Panasonic Televison & Video
How do I connect my computer to the Panasonic Viera TC-37LZZ85 so that the TV becomes my computer's viewing screen?
Presume your TV doesn't have a VGA input,
Does it have a HDMI input? So, if your computer has a HDMI output, you can watch your screen connecting HDMI
There is no other way. with a standard computer and TV.
Early personal computers had an audio/video output. I don't know if there is any similar video card currently.
Sep 06, 2015 | Panasonic Viera TC-37LZ85 LCD TV
Can I hook up this receiver to a Panasonic Viera tv tc-L32C3
U need to get a digital to analog converter for the tv digital outputs on "tv mode." Connect the analog outputs to the audio input of receiver. I had same hassle with my Viera till I got another receiver that would take direct digital input - no more need for converter.
May 14, 2014 | Pioneer VSX-D458 Receiver
Panasonic TC-32LX50 blinking red light
Could be an open internal fuse or power supply failure
Jul 31, 2017 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
We bought a new Panasonic high definition TV TC-L42D2 and we are unable to see a picture when we try to play a DVD on our Panasonic SC-HT650 System. We only get audio on the DVD. We are sure we have the...
So what's different? The TV. Anything else like the video type (s-video, composite, component)?
Perhaps if you described what cable is carrying video and the point-to-point connection to the TC-L42D2 we'd understand what isn't working.
Jan 16, 2011 | Panasonic SC-HT650 System
Blue screen but sound works fine
Check for 5vdc feeding the LCD controller board.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=TC-32LX50+
The problem can also be in the main logic board also.
Jan 06, 2010 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
I need to know how to hook up my stereo system to my panasonic tc-p50x1 tv
the audio output on the back of the set goes to the audio inputs on the stereo.
depending on age it may have aux,cd,tape,vcr,video inputs.
they will all work,as they are made for a 300mv to 1 v signal.
the one that will get overdriven severely is the phono input,never use that one except for a turntable.it is made for a 3 to 5mv signal.
a moving coil input is even more sensitive, about.1/2 mv.
Sep 10, 2009 | Panasonic TC-P50X1 50 in. Plasma HDTV
Broken screen
all you can do is chase a used
Toshiba (Theater Wide HD) Model NO.20HLV86
or buy a replacement TV
was it covered under contents damage insurance ?
this TV has been discontinued
the design of this screen means its put together
layer by layer .sandwiched ..not just a glass cover
a screen replace can't be done
unless the Toshiba company "TV parts division " has the exact same screen to supply to your local TV repair man
Even finding circuitry boards to be supplied for that model have a slim chance
Apr 11, 2017 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Tv/pc
Your Panasonic TC-26LX20 26 will only allow video inputs through the:
1. composite video/audio input ( RCA phono x 3 ) - front or rear
2. S-Video input ( 4 pin mini-DIN ) - front or rear
3. component video input ( RCA phono x 3 ) - rear
4. HDMI ( 19 pin HDMI Type A ) - rear
Depending on the output(s) available from your PC, you can use any of the following:
a. the yellow RCA female
b. S-Video output ( 4 pin mini-DIN )
c. VGA (which normally goes to the monitor) but would require a VGA/HD to HDMI Format Converter such as the one here
Should this be not enough information, please post back with what PC brand/model that you have. Additionally please specify what Video Card are you using if your PC is a desktop.
Good luck and kind regards.
Nov 17, 2007 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
Color seems inverted!!! please help!!!
CHECK OTHER TYPES OF VIDEO INPUTS. IF USING COMPONENT VIDIO CHECK YOUR CABLES ARE ALL MAKING GOOD CONNECTION, YOU CAN USE AN AUDIO CABLE TO CECK INDIVIDUAL COMP. VID. CABLES TO MAKE SURE THE CABLES ARE GOOD.
Oct 26, 2006 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Panasonic TC-32LX50 32 in. HD-Ready LCD Television Logo
103 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
