SOURCE: loacte the fuel filter on 2000 dodge durango 4.7 liter v8
if i am not mistaken the fuel filter is built into the fuel pump. which requires you to drop the tank and replace both.
SOURCE: 2000 dodge durango driver side window problem
durangos have many problems with the windows motors and regulators, I know for personal experience , because I have one, ...when you try rolling the windows down do you hear any noise coming from inside the door..if so.. the cable is busted ..you will need the windows regulator, if no, is probably the motor..you will have to check for power and ground right at the motor connector...if power and ground are present, then you need a motor ....in mine ,I pull the motor and cleaned , and they have been fine for more than a year, I starter with one and them had to do the same to all of them..hope this help
SOURCE: 2000 dodge durango kills my battery every day
I HAD SAME PROBLEM WITH BATTERY DRAINING IT TURNED OUT TO BE THE LIGHT UNDER THE HOOD WAS HANGING AND STAYING ON... GOOD LUCK
SOURCE: were to get free Owners Manual of 2000 Dodge Dodge Caravan 3.3L
Solution #1:
Contact a Junk Yard / Auto Salvage Yard and see if they have any 2000 Dodge Caravan 3.3L there. Ask them how much (if anything) for a Owners Manual. It will be the cheapest and fastest way to get one. All on-line sites have a charge far more than what is available at a Junk Yard. Some owners of Junk Yards will give them to you free, especially if you tell them you will use them for future purchases of parts. This will also tell you which Junk Yard has parts available for future parts.
Solution #2:
Mopar ATF plus 4
OR
ATF plus 4 Type 9602
Let me know if this helped, or if you have any additional information or questions. Feel free to contact me at FixYa.com!
SOURCE: how much is an oil change for a 2000 dodge durango
Check HERE for Durango owners manual.
Good luck (remember rated this post).
