Question about Kenwood KAC-9152D Car Audio Amplifier
Sub power comes on consistently for about a second and thuds
I have 2 12's (Kickers) attached to my 1000 watt kenwood class D amp.
The amp comes on and then thuds then goes back off
It does this every 3 seconds consistantly.
The head unit has no effect on the volume of the subs.
Is my amp going out?
or do i just have a bad ground?
Can you PLEASE help
  • 2 more comments
  • pritchardgra Dec 25, 2008
    no there is only one light on the amp that is the triangular power light.
    could any settings on my head unit be affecting the subs like this?
    its as if the amp gets power for a second and then shuts off.
    But it DOES NOT go along with the music just consistently hits one time then shuts off.
    is this a symptom of the amp going out?
    the model is KAC-8103D Class D Mono
  • blueextc3221
    blueextc3221 May 11, 2010
    have you removed the wiring for the subs to see if the problem goes away?
    Also verified +12VDC at the remote wire and power wire?
  • blueextc3221
    are any lights coming on the amplifier indication it is going into protection mode?
U might have bridged the amp below is ohm load, if that the case run the speakers in series instead of parraell !
Posted on Jan 14, 2009
Kicker 12L5 blew from a kicker zx750.1
MY BEST GUESS FROM WHAT YOU HAVE SAID IS THAT THE BOX WAS TO SMALL. BUT YOU ARE OVERPOWERING THE SUB RUNNING IT AT 2 OHMS ON A 750 WATT AMP WITH A SUB THAT IS ONLY RATED FOR 600. NO MATTER HOW FAR YOU TURN YOUR SETTINGS DOWN, YOUR STILL PUSHING TO MUCH POWER FOR THE SUB TO HANDLE. IT IS ONLY RATED 600 WATTS FOR A REASON. ESPECIALLY IF YOU LISTEN TO MUSIC THAT HAS A REAL LOW END AND THEN A HARD HIT. REMEMBER A HARD HIT WILL SPIKE YOUR AMPS OUTPUT THEREFORE PUSHING MORE WATTAGE TO THE SUB.
Nov 19, 2013 | Kicker Car Audio & Video
I was given a subwoofer and box but do not know where to go from here in terms of hooking it up in my car. It is a Rockford fosgate punch p112s4.
First youll need an amp. Depending on what size the sub is a 500 watt rms amp can hold up to about a 300 watt kicker. If your looking for something bigger u can get a 1000 watt amp and hook up two 300 watt kickers. To hook up the amp youll need a car amp power cable, power control cable, speaker wire, amd a car amp ground wire. They usually sell kits that run aboyt 40 bucks. The power cable goes to the batter as well as the ground cable. The power control cable goes to the back of the head unit. (You will kost likely need a more modern headunit if urs is stock). Once this is done put the sub in the box (i recomend super glue because metal nails take away from the bass). Put the speaker wire to the speaker positive on left negative on right. Same with the amp. And now ur bumpin ;)
May 06, 2013 | Car Audio & Video
I need to wire 3 woofers but 2 are dual voice coil and one is single voice coil
sure, if you wish to wire them all together, wire the first dual voice coil subs first voice coil negative to 2nd voice coil positive, second voice coil negative to single voice coil sub positive, and single voice coil negative to 2nd dual voice coil subs 1st voice coil positve (again with the second dual voice coil sub, run the first voice coil negative to the 2nd voice coil positve) your speaker leads will be attatched to first dual voice coils 1st voice coil positive, and 2nd dual voice coils 2nd voice coil negative)
Apr 01, 2013 | Kenwood KAC-8104D - 1000 Watts Class D...
I have 2 15" dvc 4 ohm kickers 1000 watt / 500 rms &a1000 watt avionixx 4 channel amp what would be the right wiring scheme?
need to know the ohms on the amplifiers then might can tell you best solution for system
Mar 05, 2013 | Car Audio & Video
So I have the first kickers that came out the 15 will a 800 watt amp push um without eather blowin out
If you are referring to the Kicker L5 solo-baric subwoofer, then an 800 watt peak amp will not blow even one of those subs. The L5 is capable of handling 1000 watts peak and 500 wrms. An 800 watt peak amp will usually have around 400 wrms. Underpowering the subwoofer will not hurt the amp or the sub(s).
Mar 07, 2011 | Car Audio & Video
I have 2 15 inch L5 solo baric subs and need a amp?
the 15" l5 is rated at 750 watts rms so i suggest you get an amp with atleast that much power because if you get a amp weaker than that you run the risk of clipping your subs and blowing them
Jul 15, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have 2 kicker l7 12s 4ohm speakers and was
Hello gonenutz14,
It depends on how you define the "best way". Driving each sub with a separate 750 watt amp will result in about 50 percent more power than having them share the output from a single 1000 watt amp. But with 2 amps, there's more wiring issues to contend with and the adjustments are more complex. The 2 750 watt amps will cost more than a single 1000. Plus if the 1000 watt amp is stable to 1 ohm, the power difference will actually be less than 50 percent because of the lower impedance. But if the 750 watt amps are also stable to 1 ohm and their outputs can be combined, we're back to 2 being better than 1.
I'd say that the simplest, most economical way is to use a single amp. If maximum power to the subs is the highest priority, and cost and wiring is not an issue, then 2 is better.
Hope this helps.
Jul 12, 2009 | Car Audio & Video
Constant thudding of bass from sub
try installing a power condenser most audio stores sell them
Mar 23, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 29, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
95 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
