Question about Toshiba Satellite Pro 6100 Notebook
Toshiba 6100 Where is the RTC battery located On a Toshiba 6100 Satellite Pro ? How does one get to it to replace the RTC Battery? Thanks
  • DEREK NORONHA Apr 23, 2007
    Wow,
    Never realized the RTC battery could be so complex to replace.
    So I shall heed the above advice and take it to a service centre.
    This laptop could have been better designed for access to replacment items !!
  • Anonymous Mar 25, 2014
    How do I change this battery?
  • 624 Answers
Unfortunately it is a fairly involved procedure, one of the more complex I?ve seen for a newer laptop. If you don?t have prior experience, tools and some nerve I?d suggest you take it to a shop. Some of the more challenging parts you are going to remove are the keyboard, the top half of the case, the wireless card and some of the wiring harness. -Remove the battery pack, any PCMCIA cards, the optical drive and the hard drive. -Open the laptop and carefully pry the keyboard holder (thin piece of plastic at the top of the keyboard. Toshiba has a special tool for this but in times past I have been able to successfully remove other Satellite Pro series keyboards with a plastic probe. Once that is off remove the two retention screws at the top of the keyboard, carefully disconnect the cable and remove the keyboard. -With the keyboard removed you will see the wireless card torx security screw at the top just to the left of center. Remove it, the cover plate and the card underneath. In order to remove the card you will also have to disconnect the white and black coax leads. When removing and reassembling note that these connectors are really small and fragile. -Flip the laptop over and remove all 15 screws. There are three different types so mark down where they go for reassembly later. -At the rear of the computer you will find 2x screws, one to the right of the VGA connector and the other in-between the serial and lpt1 port; remove them as well. -You will have to disconnect several leads and wire harnesses in order to lift off the top half of the case. -Once the case is removed the RTC battery is in the lower right hand corner. -Now all you have to do is reassemble the laptop and test. Good luck and don?t forget to rate this post.
Posted on Apr 16, 2007
    Problem Solver:
  • 12 Answers
It's on the motherboard and you'll have to take the system apart to get to it. There's a step by step instruction set here http://www.irisvista.com/tech/laptops/Toshiba6100/Toshiba_Satellite_Pro6100_dismantle_1.htm Take a look at step 16 ... "Lift off the battery board with the RTC battery to disconnect it from the system board. " So you'll have to get to at least step 16 ... I'd recommend you take it to a local repair shop as this isn't something for the faint of heart.
Trying to locate CMOS battery on MB of Toshiba Satellite Pro 6100
It's flat and circular like a watch battery or a hockey puck.
Mar 08, 2011 | Toshiba Satellite Pro 6100 Notebook
My toshiba satellite pro 6100 will not turn on. The battery light and power light turns green but it will not turn on.
The problem could be your display. Use the VGA port on the side of your laptop to connect it to a computer monitor, this will let you know if your system is posting or not. (If you see the Boot Screen it is posting).
May 19, 2010 | Toshiba Satellite Pro 6100 Notebook
Where is RTC battery located on Toshiba Satellite Pro 6100?
RTC (clock) battery is attached to the battery charge board - it's located underneath the mouse buttons.
Feb 16, 2010 | Navman ICN620 GPS Receiver
While using the laptop on battery it unexpectedly shuts down then when restarting it states that it is a bad RTC Battery (replaced 2 months ago as it said the same with the first one) Bad check sum (CMOS)...
aside from the battery (big one) there is another battery connected to your motherboard, it is not accessible unless you open the casing of your laptop.
bring it to a service center and have it replace(it is almost a size of a watch battery)
Nov 05, 2009 | Toshiba Satellite Pro 6100 Notebook
ReplaceToshiba Satellite Pro 6100 laptop CMOS battery
the cmos batt is located near the cpu, is a quarter look alike batt. disconect it fron the two cable connector to the mb and replac e with a new one.
Jul 16, 2009 | Toshiba Satellite 5005-S504 Notebook
CMOS or RTC battery for this laptop : can it be replaced
Hi AshishB, Yes, Toshiba does refer to the CMOS battery in their literature as the real time clock battery. Your retailer is half right, the battery is on the motherboard but its attached via a connector and it can be replaced. Here are links to a couple of venders that sell the RTC battery for your laptop: - Http://www.sparepartswarehouse.com/Toshiba,Satellite,L15-S104,Laptop,Batteries-Backup-RTC.aspx - http://cgi.ebay.com/Toshiba-Laptop-motherboard-battery-cmos-L15-S104_W0QQitemZ170060189842QQihZ007QQcategoryZ3666QQrdZ1QQssPageNameZWD1VQQcmdZViewItem Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 18, 2007 | Toshiba Satellite L15-S104 Notebook
Toshiba Satellite Pro 6100 Notebook Logo
255 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
