Question about Dell Axim X50v Pocket PC
Second Battery - not recognized
I have not used the axim in awhile but it has been in the cradle, hooked to my PC and syncs with Outlook all the time. I have the second battery and it is fully charged in the cradle. It worked when I first got the gadget. When I turn the axim off - open the battery cover switch - remove the battery cover - take the smaller battery out - put in the bigger one - lock the battery cover switch - the axim will not turn on. But, if I place the axim in the cradle active sync will wake it up. I can take the axim out of the cradle and use it. But, if I turn it off, it will not turn back on. All works well with the regular battery with the battery cover on and locke. I recently upgraded the software to VGA - ROM version A05. I am going on a trip and need to be able to turn it on - as if it were a stand alone device- when using the extended battery. Any help for me? Thanks!
  • Joan Euler Apr 16, 2007
    I figured out my problem.
    I did not remember that I had a special cover for the second battery. DUH!!!!
    Found it, placed it on the axim and it worked!!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 178 Answers
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
Dell Axim X51 and Vista
You need to download Microsoft exchange server to syncronize outlook on different computers.
Apr 18, 2008 | Dell Axim X51 Pocket PC
Can't Sync to my PC!!
You see the icon of Axim X5  on my computer???
Oct 31, 2007 | Dell Axim X5 Pocket PC
How do I sync axim to outlook?
Try deleting the active sync partnership as mentioned in this post -
http://www.aximusers.com/forum/axim-x51-x51v/6651-synchronize-outlook-contact-problem.html
Jul 17, 2009 | Dell Axim X51v Pocket PC
NEW DESKTOP COMPUTER RUNNING WINDOWS VISTA
all you havce to do is hook up the cradle to the USB port, and you MIGHT have to and i stress this because it will usually open on its own, you may have to open windows mobile device center, its in your programs menu, activesync is no longer used in VISTA, so any attempt to put it on will probably be stopped , once oyu plug in th ePDA check for updates, this will ensure that you have all the drivers for the Dell X30 (i)
Jan 03, 2009 | Dell Axim X30 Pocket PC
Dell Axim x51 will not connect to system
windows vista uses its own sync software, which is available on the windows marketplace
if your vista is original you can upgrade to this software
if you use xp version, just keep using the usual active sync
Oct 04, 2007 | Dell Axim X51v Pocket PC
Connecting Axim plus Palm on the Same PC
I may be wrong but each PDA (assuming you are connecting different brands) have different drivers. I connected a Toshiba and Dell PDA and each required their respective install disk with their respective drivers. Then I configured each pda using the Active Sync Connection Wizard. Everything ran smoothly after that.
Sep 14, 2005 | Dell Axim X3 Pocket PC
Restoring Backup to New Axim
The backup utility included on your Dell Handheld will backup your data to a storage card. You can restore on your replacement handheld from that storage card. From your Host PC, you can go to Tools | Backup/Restore and do a backup to the Host PC, and you can then restore after syncing the replacement handheld for the first time.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Why does my axim power on by itself?
I've noticed that mine will power itself on as well. But is usually goes like this... 1. Sync with computer 2. Unplug cable 3. Turn off Axim 4. ~1min later...Axim is on and at the password screen
Help active sync will stay in limbo attempting to connect to cradled axim
Does your system detect the handheld? After you connect the cradle or cable to the computer, then you should be prompted to install drivers for the handheld. Make sure that Dell Pocket PC appears in the Device Manager.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Dell Axim X50v Pocket PC Logo
117 people viewed this question
Clive
Clive
Alun Cox
