Question about Proscan PS50700 50" Rear Projection Television
Hooking up a dvd player
Followed directions and only get sound , no picture
we have tried 2 different players with the some results
    Scholar:
  • 150 Answers
Hi, either you have the yellow (video) cable in the wrong place on the back of the tv or your not switching the tv to video input 1,or 2 etc. check that your cables are coming from video and audio OUT of the dvd player to video IN on the back of your tv. Be advised there are video IN`s and video OUTS on the back of your tv, you must attatch to video input 1,or 3, 4 etc.and then go to the front of the tv and push the input or source button on your remote until you see the dvd which should already be playing so you`ll see it if you go bye that input, gl, video-tek
Posted on Feb 08, 2009
The DVD player is running a movie with no picture or sound, the TV screen is showing an icon that says no signal...How do I get the movie to run with sound?
try using a different input on your tv. If possible try using a different cord to hook the dvd player to the TV. If neither solution works it sounds like a faulty dvd player.
also try using a different source on the tv like another dvd player, cable etc. etc. hopefully on the same input to make sure the tv is working properly .
Mar 03, 2011 | Dynex Televison & Video
I tried to hook up my dvd player and i get picture but no sound. when i put the cords in the back of the monitor there is yellow red blue green holes no white spot. Do i need different cords. I have tried...
That could be a result to that TV either not having the ports you need, or you may need different cords. On my TV. With the 360 they have two cords. Red,white, and yellow and also green blue and i think red but im not 100% sure. You may need to find a different port on your TV for your cords, or do what I do and have your VCR hooked up to your tv, and your DvD player hooked up thorugh your VCR. Hope this helps and don't forget to rate ^^
(and yes that yellow and white are a necessity)
Feb 23, 2010 | Computers & Internet
DVD player died during movie. When disc is inserted the player makes soft 'whirring ' sound - but alas no picture/no audio. Tried several different discs. Same result. HELP!!!
Sorry, but it sounds like the DVD player is just gone. You can attempt to have someone repair it, but with the low cost of new DVD players, it probably isn't worth it.
Jan 10, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
I can't get a picture on tv when turn on dvd player why? brand new, never used before.
have you connected the DVD into the right plugs, also are you using the correct AV channel on the TV?
RED WHITE YELLOW yellow is video red is L sound White is r sound. check both TV input and DVD output
Aug 14, 2009 | RCA DRC8335
Has sound but no picture
try a different rca cable, or even putting into a different input. Example, if you have dvd player hooked into input 2, and you have a input 3, try your connections there and see if you have the same problem. If so, use a different rca cable or whatever your cable maybe that you are using :-)
Apr 07, 2009 | Akai LCT3701AD 37 in. LCD Television
My DVD player quit working. It was plugged into my Yamaha amp. I hooked up another dvd player, I get sound and no picture. When the dvd player is connected directly into the TV there is picture & sound. I...
Try using the composite video or SVHS video outputs on the original DVD player with the Yamaha amp. The other DVD player might have a switch on the back to select composite or component video outputs.
Dec 13, 2008 | Audio Players & Recorders
No color
Please set your TV on Auto Color system to get colors on VHS and DVD.
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
I have sound but no picture
The TV could be on the wrong channel.
Make sure the video cable is going from the OUT of the DVD player to the IN of the TV.
Try multiple discs to see if same result.
Sep 04, 2008 | Toshiba SD-K740 DVD Player
Philips 26
There is an input imbalance. Either try connecting your cables to different inputs on your TV, or try connecting to different outputs on your DVD player. (Only worry about the yellow video cable bit initially). Alternatively, try a different cable type; you'll have some ins and outs that don't use RCA connectors.
Mar 03, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
DVD picture flashes on & off
our problem was because the hdmi on reciever was not compatable with hdmi on dvd player, different versions ex. 1.2, 1.3 , 1.1
ended up using component inputs instead
Dec 16, 2007 | Toshiba SD-6000
Proscan PS50700 50" Rear Projection Television Logo
77 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
