Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
My Philips HDTV 60PP9202 has blue and red curved lines
My HDTV has blue and red curved lines that just appeared suddenly. Was working fine in the morning, but once I disconnected my xbox 360 and turned it back on, the curved lines were there. What can I do? Or what is the problem?
  • Philips Master
  • 3,459 Answers
Check to see if you can adjust the convergence. If you can't adjust the red and blue in all directions you need to replace the convergence chips and resistors. If you not sure how to check the convergence goto the site www.TvRepairKits.com and goto the Tips section.
Posted on Dec 30, 2008
Where do i purchase the red,green and blue bulbs for a phillips 60pp9202
i DOUBT those are available and the blue is about the only one I have ever seen bad.
What is the set not doing? ----may be able to help if I know.
Dec 06, 2012 | Philips 60PP9202 60" Rear Projection...
I have a Phillips 60PP9202 60in. rear projectiov HDTV, but the red and blue colors are outlining the faces
you need to replace the convergence ic's you can get a convergence kit from.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.tvrepairkits.com/xcart/home.php?partner=larry
techman
Feb 18, 2010 | Philips 60PP9202 60" Rear Projection...
Convergence issue... I tried to manually fix it through the menu option without any luck. The convergence does curve at the top and bottom of the screen.
It seems the solder is broken in Vertical Convergence Amplifiers or it is damage internally. This model has 2 Conv. Amps: 1 for Horizontal (Red, Green and Blue) and 1 for Vertical Convergence output (Red, Green and Blue), if the convergence does curve at the top and bottom, it is because Vertical Converegence output is no good. The Conv. Amp. costs around 20 dlls. Thats why you can not fix it with the Menu option. Good luck!
Nov 13, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 red shadow in the battom of the screen
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9502 60" TV has problem with Red convergence or red and blue fringes
You will need to replace both convergence ICs they are both STK392-120 and you will also need four 6.8 ohm 1 watt resistors. you can get the Convergence ICs and resistors at the following link and they provide free instalation instructions with pictures so you can do the repair yourself. Here is the link.
http://servicemanuals.vstore.ca/
Jul 06, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60 in. Help
You will need a service call by a qualified technician....
Red & green = yellow, therefore the blue CRT has a problem..T.
Feb 12, 2008 | Philips 60PP9202 60" Rear Projection...
sound like your convergence amps are blown. also known as stk's
Dec 19, 2007 | Philips 60PP9202 60" Rear Projection...
Blue Converge alignment
Needs convergence circuit overhaul.....
1)pull chassis
2)replace STK392-110 x 2 IC's
3)Reset alignment
Usual repair cost around 400.00.............T.
Oct 21, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
187 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
