Question about Homelite 'Yard Broom' Leaf Blower
Homelite ht 17 hedge trimmer won't stay running
The only way this motor will run is if it's primed thriugh the carb and then dies after that burns off,,,don;t know if the primer bulb isn't working right or if maybe the black diaphram how gotten too old and effecting it or an internal carb problem. This trimer was given to my son and don't know what has been done to it, if possible can you tell what the turns out are for the low and high mixture screws? Can't find any manuals for it.
    President:
  • 2,692 Answers
Homelite support page was no help.    Usually with these small engines you start the needle placment by lightly seatign the needles all the way in and then  1and 1/2 turns out.    That is enough to get the engine started, then ajusted while running almost always father in. Idel jet at idle , of course and high speed jet under load,if possible. I would start with the carb first as that is the most likely problem.
Posted on Dec 25, 2008
Fuel Ratio What is the fuel Ratio for the Homelite HT -17 Hedge trimmer?
2 stroke tools generally run at 50:1
100ml of oil in 5L of petrol
Oct 29, 2015 | Homelite Garden
Homelite Hedge Trimmer HT-21 engine runs, but blade doesn't move
check the plastic gear where the engine meets the trimmer head
Aug 07, 2012 | Homelite Garden
My 26HT reconditioned trimmer will start and run on full choke but, if I take it off to middle choke, it dies. It doesn't run right on full choke but does rev up enough to engage the blades. Has...
sounds like a carb problem You will have to take the carb off and strip it down to parts clean out all the ports with a good cleaner I use brake clean reassemble and reset the High speed and low speed jets at 1.5 turns out then adjust from there
Jun 14, 2011 | Homelite Factory Reconditioned 26cc...
Wat is mix ratio for homelit ht-17 hedge trimmer????
If ever in doubt, always run them on a 25-1 fuel oil mix, this is good for any small two stroke engine, always use a good two stroke oil designed for use in chainsaws, not out board oil.
Apr 17, 2011 | Homelite Garden
How do i start my homelite ht -17 hedge trimmer
it sounds like your throttle cable is to long i have the same problem with mine... when starting up pull the throttle full on with your finger whilst you have it set on choke. best to do this on a very flat surface.
Nov 03, 2010 | Homelite Expand-It Hedge Trimmer...
Homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
My Homelite 26 HT Hedge Trimmer is stubborn to start and then only runs on Full Choke at full throttle, but not smoothly. Whats up with this?
Jets in carb are dirty. Take carb off and clean, blow out all jets, you may have to use thin wire to get all gunk out. Also fuel line might be dry rotted. Put carb back on and adjust settings on carb.
Jun 18, 2009 | Garden
Can not find parts
www.discountonlineparts.com
Apr 18, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite 'Yard Broom' Leaf Blower Logo
1,944 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Homelite Garden Expert? Answer questions, earn points and help others
