We are using the Oracle 8 reports from the LAN net work. We asked from the local experts. I may get solution may at tomarrow.
SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
SOURCE: Setting Paper Size in Epson Fx-1170
Use the personalized paper size, and set the wide an lenght of the paper you are using.
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
SOURCE: Epson FX 2175 Matrix Printer page skipping"
Its in your settings go to the control panel where the printer is shown as the default printer with the checkmark beside it and right click and click on properties and check there.
