Question about Microsoft SideWinder Precision 2 Joystick
Joystick does not feed back any force, and does not centre itself
I have just connected the Microsoft Sidewinder 2 joystick to Condor, the gliding flight simulator. I have gone to Setup\ Input, and marked the check box with a tick to show the program is connected to a force feedback joystick. Also, I have set up the elevator so that it is marked "stick centres with hands off" .
The joystick is floppy - it does not centre at all, and there is no detectable force feedback, even with Setup\Input\Assign Controls\'stick force simulation' set to maximum.
Just for the record, the other controls are working fine - ailerons, elevator, airbrakes (set up on slider which I believe is normally throttle on a power plane), point-of-view hat, trigger (for panel zoom) and button 3 for point-of-view re-set. So far, I don't need other buttons but assume they will also be working OK.
Can you help please?
Thanks,
Geoff.
  • geoff_rose Dec 25, 2008
    Sorry, but this suggestion is not practical and so, with respect, is of no help. I don't know anyone else with another Microsoft Sidewinder 2 force feedback joystick, which I could borrow and try out, which would be the only useful comparison with my own unit.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a couple of ideas:
  • update the USB drivers of the Operating System from the motherboard manufacturer not from Microsoft;
  • try other USB ports;
  • disable Power Management (auto switch off) of the USB Root Hub.
If all else fail, then return the Sidewinder for a replacement.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 25, 2008
  • Microsoft Master
  • 19,396 Answers
Try first performing a complete calibration procedure, if that does not work, that means that the joystick is probably faulty.
    Genius:
  • 1,269 Answers
Please double check if the joystick is compatible with your console. Make sure they are. Also double check the physical connections if they are tightly plugged in. A firmware/software update can fix the issue if everything seems to be fine.
    Sergeant:
    Novelist:
  • 327 Answers
  • 741 Answers
The only way to diagnose your problem is to get another joystick and try it. If it does not have any problems then you know that the joystick is malfunctioning.
  • Randall  Trahan
    Randall Trahan Dec 26, 2008
    It may not be practical, for you, but it is a good commom sense approach to fixing your problem.
Unable to connect Joystick in Game Controlers
What game are you trying to play? Most newer games don't know about the old game ports anymore. That could be the cause.
Nov 11, 2012 | Microsoft SideWinder Force Feedback Pro...
Sidewinder force feed back joysticks
i have 3 sticks that i want rid of some need new micro switches fitted , i have the switches all you need do is fit the switches i think i have an instuction somewhere on how to pull a sidewinder 2 apart
May 16, 2012 | Microsoft SideWinder Force Feedback 2...
SideWinder Force Feedback 2 Joystick: need new drivers for vist...
For Windows XP , Vista and windows 7 it dont need drivers windows has them built in.
May 17, 2010 | Microsoft SideWinder Force Feedback 2...
I need drivers for microsoft sidewinder force feedback pro joystick that works with windows 7 64bit
buy a joystick that will work with win7, because the MS Sidewinder has no driver, and MS has no vested interest in developing one...
Jan 18, 2010 | Microsoft SideWinder Force Feedback Pro...
Microsoft Sidewinder Force Feedback Pro 2 Drivers
You should be able to download them from the Microsoft web site.
Jun 15, 2009 | Microsoft SideWinder Force Feedback Pro...
The Software
I have same stick, that same software wont work with xp or vista depending on what game you have you should be able to set up in input settings for the game , there was a patch at one time that someone made up you mite want to try here and do a search > http://forums.ubi.com/eve/ubb.x?a=frm&s=400102&f=49310655
Grazz.
May 18, 2008 | Microsoft SideWinder Force Feedback 2...
Microsoft sidewinder force feedback 2 joystick
Well, I just noticed this exactly same problem with my new PC, so i try it with my older PC and it works fine, I´m not sure if this has something to do with the USB 2.0 or the driver, but i was not able to find the version 5.X for it, microsoft page only has the version 3.2.
the extrage part is that both PCs are using the same version of WXP.
Feb 22, 2008 | Microsoft SideWinder Force Feedback Pro...
Microsoft Sidewinder Force Feedback 2 Joystick
There are two x sensor holes in the grip , one top one bottom, they control the force feed back gimbals in the base you need from time to time make sure they are clear just spray them with some alcohol base solution and give them i light probe with a tooth pick to make sure there is no gunk blocking up the holes .
Good luck.
Grazz .
Dec 27, 2007 | Microsoft SideWinder Force Feedback 2...
Microsoft SideWinder Precision 2 Joystick Logo
57 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
