Question about Maytag MER5775Q Electric Kitchen Range
Oven won't heat
I have a range that seems to work fine except that it can take 25 minutes for the oven to heat to a required temperature. Is this normal? how do I go about trouble shooting the problem? I think both elements are working.
    President:
  • 1,462 Answers
25 mins for oven to reach temp is not unusual. if it reaches temp ok across the range, don't think you have a problem
Posted on Apr 16, 2007
Temperature control ?
Heat is produced by control sending voltage to elements. Heat is measured by oven sensor or thermostat. Could be a bad element, oven sensor, thermostat, or control.
Nov 04, 2017 | Kitchen Ranges
On a Frigidaire Gallery oven, it takes forever for the oven to heat to the set temperature. 20-30 minutes. This seems like a very long time. Once it reaches the temperature the oven temperature is fine,...
Replace the door seals, they are the thin rubber strips around the front of the oven when the door is open. They are simple to change as they just clip on.
Jun 26, 2014 | Hotpoint RGB745 Gas Kitchen Range
Thermador dual fuel oven temperature not accurate and the dials dont match temperature
Faulty thermostat it's the thin copper shaft in the oven that has a skinny tube running from it if you remove the oven knob you will find it goes back to the switch. Needs replacing.
Apr 21, 2014 | Thermador P304CS Gas Kitchen Range
Oven won't heat up when baking (Maytag MGR5775QDS)
Check the Manual/Auto Clock setting to be on Manual not auto . The Oven is waiting for the Right Time to start up .
Jun 13, 2012 | Maytag MGR5775QDS Dual Fuel (Electric and...
Need help
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 21, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
BKRC21V Electric oven, gas top
Read your owner's manual. That will answer all your questions.
May 05, 2017 | Baumatic Louisiana Dual Fuel (Electric and...
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
GE OVEN DOES NOT WORK PROPERLY JBP69SGH2SS
I am not an expert, but this has happened to me. Examine your circuit breaker and see that it provides the amps that your oven requires. If it just barely provides it, then it could be that your circuit breaker is tripping if you have anything else on that line and it is being used. Especially hair dryers. If your circuit breaker is not tripping, you should contact GE or repair service because you may have a "power module" problem. Good luck.
Nov 30, 2006 | GE JBP69 Electric Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
163 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
