Question about Amana ACE208 Convection/Microwave Oven
Volume control My work recently purchased a second hand convection microwave which looks similar to an Amana ACE 208 (although I'm not 100% sure of the model) It didn't come with a manual, and the alert when it finishes cooking is very loud. Is there a way to change the volume setting?
  • catherine Carlin Apr 16, 2007
    it's actually a menu master jet wave (later aquired by amana) Would it still be factory set? The volume is so loud it's an oh&s issue so if there's any way I can fix it i'd be grateful
It's ok, I found a manual.. There's a hidden panel which allows you to change the factory settings. Thanks for trying though.
Posted on May 29, 2007
    Problem Solver:
  • 18 Answers
You can't adjust the volume on any microwave in the world(Though I am not %100 sure)
  • Benjamin Hill
    Benjamin Hill May 30, 2007
    (I think you can adjust the volume on some microwaves)
  • Benjamin Hill
    Genius:
  • 1,074 Answers
No there is no way to adjust the alert they come already factory set.good luck
Posted on Apr 16, 2007
Is there something else I can do before purchasing a convection motor for the Amana ACE 14 convection express combo oven. The convection motor hums and turns very slowly but will not spin when turned
Well, running that slow makes it a serious fire hazard, it needs the air circulating to spread and dissipate the heat. Other than having a pro look at it, I would take it apart and clean all the moving parts, esp. the fan motor/drive and fan blades. Dust, fibers, lint etc. can build up very quickly when near an intake port. If the surface of any component is oily it makes the build-up even worse. I've saved a ton of money by doing this, the latest example being a dishwasher that was going to be thrown away. I cleaned and re-assembled it and it worked great, they are using it to this day. The same thing applies to computers, laptops aren't too bad, but towers are a different story. If you haven't opened up your computer lately, or ever, you should do so. I think you'd be surprised. Hope this helped. Grim
Feb 13, 2015 | Amana ACE14 - Convection / Microwave, All...
Microwave trips and switches off within 2 seconds
We regret reading about your microwave. At this time we recommend you have the unit evaluated by an authorized service center.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-S254BF Microwave Oven
Spec sheet for the Amana HDC18 and HDC 21. Straight 208 vac 3 wire? Control transformer included or do I have to supply a neutral?
The service manual is at our site here.
Jan 15, 2010 | Amana HDC18 Microwave Oven
Microwave heating not working. convection is fine
Therer could be many causes for this and will need to be looked at by a qualified repair tecnician, I would suggest that you ask for a quote first as the repair could be simple of very expensive.
Hope this helps
Jan 07, 2010 | Microwave Ovens
I got this microwave in my house, but its not working. all the buttons are not working accept stop/cancel button. please send me the sollution.
I have a similar microwave that I recently repaired. NN-9854 (bad capacitor). So your microwave functions but you cant stop it unless you unplug it, it ends its cycle, or you open the door? Does it beep when pressed? If not, you need a new control pad.
Dec 19, 2009 | Panasonic NN-T888S Convection/Microwave...
Ace 208 comes up with "hot" in display amana tech say not possible no code like this
Hello I´ve repaired a couple of ACE208 with hot message in the display. The problem is in the convection fan located on the back of the oven cavity, turn the oven on and quickly open the door and look inside to see if the fan is spinning (slowing down, the fan stopps when you open the door but you can see it slowing down) if it is not spinning the supporting screws of the fan sometimes loosen up causing the fan to hit the oven walls preventing the fan to spin freely -probably before the problem started to happen you could hear a loud noise- the fan can´t move the air throgh the warming elements causing them to overheat hence the hot message. The fan motor rarely fails so all you need to do is remove the stainless steel cover and the back black cover and tighten the mounting screws of the convection fan and clean it if it´s dirty. Hope this helps, both the ovens with hot message I have repaired get the green tag just by doing this or replacing the motor, I have no knowledge of other problems that may cause this.
Dec 02, 2009 | Amana ACE208 Convection/Microwave Oven
Microwave/convection oven in our fifth wheel will not run past 59 seconds. For example trying to reheat a cup of coffee set at two minutes - it will only run for 59 seconds. I am afraid to try the...
looks like the timer brain has packed up on you,,
how old is it,, it may be cheeper to just replace the microwave as there not very pricy now,,there is very little inside them that you could fix your self, however,, putting your hand inside the back could kill you? so dont try it, play safe buy a new microwave insted
Oct 26, 2009 | Sharp R-1870 Convection/Microwave Oven
Amana OTR Convection Microwave runs 59 seconds and shuts off
This sounds like either a thermistor or a damper switch/motor problem.
Amana's technical support line is 866-426-2621. This is the commercial side but they should be able to get you in touch with the domestic side.
Sep 12, 2009 | Sharp R-1850A Convection/Microwave Oven
Amana ACE208 Convection/Microwave Oven Logo
231 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
foster_mommy
Level 1 Expert
Jim Thurston
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
