Question about Dell Dimension 4600 PC Desktop
Unable to open a program
Attempting to open a program (WindowsXP
Home operating system) I get Error message: File Corrupt and that I should restart the program to invoke AutoFix. However, program will not "restart". This may be connected to my computer not shutting down when given the command to do so. It was suggested that the program I am trying to open may not have shut down previously and that program first needs to be cleared. If this is the case, how do I find this to clear it?
    New Friend:
  • 21 Answers
Hi, you will have to install a new and original operating system. But before that, I will advise you to get an external hard disk to copy all your files, because it could involve you formating the system. After that, load an active anti virus, then tranfer your file back. That's it. You can mail me for any question. abbeyglobe at yahoo.com. Good luck.
Posted on Dec 25, 2008
When I try to open a cookbook I get a dialog box saying Unable to create view: 'cbks'-'open'
I started receiving this same message today also. In addition, when I do a search by ingredient in the Search feature and try to open up the recipe I get the same message with the words 'Rcpe' - 'open' instead of the 'Cbks' - 'open'
Aug 06, 2013 | ValuSoft MasterCook 11
How to fix and repair a not valid win32 application?
Often this error message will be similar to the below error message.
C:\Program Files\myprogram\program.exe is not a valid Win32 application.
Cause
This issue can be caused by any of the below possibilities.
File is corrupt, bad, or missing.
File is not designed for your version of Windows.
File is a virus, worm, or other malware file.
Hardware incompatibility.
Answer
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install or after the program has been installed because it was not copied properly onto the computer.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
If the program is an older MS-DOS program or early Windows program you may get this error.
If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Getting old MS-DOS games to run in Windows.
This error can be generated by a file that is a virus, worm, Trojan, or other malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus or infected.
If the file has been checked and is clean, it is still possible that the virus protection program or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue.
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
Source : ( http://www.computerhope.com/issues/ch000726.htm)
May 30, 2011 | Microsoft Computers & Internet
Hi when i trying to load os it gives crc error sometimes at 4% sometimes at 18 % please help
Issue:
Cyclic Redundancy Check or CRC error.
Cause:
This error message could be generated by any of the below reasons.
1. During the transmission of the file it became corrupt or bad
2. The file was sent inappropriately
3. The device being opened from is bad or contains errors
4. The file itself is bad or the program attempting to open the file is bad.
Jan 05, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
I recently went to open onenote, and error message appearead saying: "OneNote is unable to start. This may be caused by insufficient hard drive space or by insufficiant write permissions for OneNote's...
You .one file might be corrupted.
In this case due to programming method how to fix corrupt onenote files In some steps program can restores your onenote file backup or simply corrupted file by any reason
Sep 05, 2010 | Microsoft OneNote for PC
Error 2350
THE PROBLEM The Windows Error 2350 occurs when the installed version of the Windows Installer is too old for the MSI to execute. The registration entry for the engine has been damaged and all attempts to execute the MSI installation packages will not be successful.Errors on your system may be caused by invalid registry entries and outdated or corrupt drivers.
THE SOLUTIONTo fix the registration entry for the Windows Installer, the Installer service should first be registered then unregistered using msiexec /unregister and msiexec /regserver (Type both command in run) or the command line switches. The user will then have to restart Windows.
Feb 12, 2010 | Microsoft Windows Vista Home Premium with...
Cannot run application (*.exe)
what is the application?
It sounds like you are trying to run a Win 16 (Windows 3.x) program
Jul 26, 2009 | Dell Inspiron 1420 Notebook
Error occur during compiling,unable to open a header file
The compiler is attempting to access the iostream header file and it either cannot find the file (not in the default location or it has been told to look in another location where it doesn't exist), or the file security is set so the current user does not have read access to the file.
Apr 15, 2009 | Computers & Internet
Error Message 'F:\ setup.exe is not a valid win32 application'
  1. File is corrupt, bad, or missing.
  2. File is not designed for your version of Windows.
  3. File is a virus, worm, or other malware file.
  4. Hardware incompatibility.
Answer: File is corrupt, bad, or missing
Download files
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Bad file
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Mar 18, 2009 | Computers & Internet
Unable to load Roxio Creator 2009. Message says 'wizard was interrupted, your system has not been modified'. My operating system in Vista Home Premium.
During the installation of DirectX 9 portions of Creator 2009, the installation halts, it perhaps tries to roll back, gives an error....wizard was interrupted ... and cannot be completed.
Resolution
Open My Computer (or Computer for Vista users) from your Start menu.
Go to C: drive -> Windows folder -> System32 folder.
Look for a file called dsetup.dll in the System32 folder.
Rename the file to "dsetupOLD.dll" or delete the file.
Reinstall Creator 2009 and follow the on-screen instructions.
It helped some..
Dec 17, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
Alun Cox
