HP Scanjet 3570 Flatbed Scanner
Problem for HP Scanjet 3570 Flatbed Scanner
Can't open Hp director
By the_white749 on Dec 25, 2008
hp director wont open
Best Solution
posted on Jan 02, 2009
Very Helpful)
Chittaranjan
Rank: Guru
Rating: 89%, 45 votes
I read ur problem.This problem with HP director occurs if you are running Internet version (7.0).If u have difficulties knowing your Internet version, pls do the things mentioned below.
1.Open internet explorer->click help->then click on "about internet explorer".---There you will see the version of your browser.
SOLUTION.
If see an hour glass appearing and disappearing without displaying the HP director window after clicking on HP director, You got the following solutions.
Solution 1.
1.Double click HP director icon.
2.Then Press Alt + space key together.
Result:YOU will see a small pop menu appearing on the desktop screen.
3.Click on "minimize" on that pop up screen.
Result:Now u will see a tab on the taskbar.
4.Right click the tab(hp director),then click restore...Now you will see your HP director window.
Note: Above solution should be performed while trying to open HP director.(ie) You should try this every time if u want to open HP director.To go for full time resolution,then try solution 2.
SOLUTION 2:
1.Open "www.HP.com"
2.Select "software and driver downloads"
3.Type your product name in the "for product text box",then hit enter.{(eg) if u type 7410 for office 7410,then u have to select the exact model in the next window}
4.Select the operating system.(if u dont see a option to select operating sys, there u will see "software and driver downloads"
5.In the next page, you will see a list call "Updates" you have to download a update which says "
Critical update to resolve an issue with HP Director after installing Internet Explorer "
6.After downloading the update, run the file and thentry to open HP director it will open the director window.
This will work.I assure u total problem resolution
Regards
Chittaranjan
Comments:
Jul 14, 2009
- HP Director Window Does Not Open in Windows XP.
for more help please visit the below site.
http://ithelpdesksupport.blogspot.com/ OR http://ithelpdesksupport.blogspot.com/2009/03/hp-director-window-does-not-open-in_29.html
Was this helpful?
Yes
No
12 people thought this was helpful
Solution #2
posted on Oct 14, 2009
Not Rated)
reeltoreelgy
Rank: Apprentice
Rating: 0%, 0 votes
This is for all those having similar issues. I had downloaded the software successfully. After more downloading of other programs it stopped opening. Then it disappeared from the screen. My solution was to go to the add/remove list and remove anything related to HP K80,  the all in one I use. After that I went to HP and reinstalled the K software driver from their site. I used IE8, download only, and then install. A long process. It is done when REGISTER screen appears. Choose no, don*t remind me and close. I also chose not to set up fax functions on screen. The printer is listed in the large printers screen, the fax is not. The director will now open from the desktop. I hope this helps.
Was this helpful?
Yes
No
Popular Solutions for HP Scanjet 3570 Flatbed
Questions and Unsolved Problems for HP Scanjet 3570 Flatbed
Do you recommend HP Scanjet 3570 Flatbed Scanner?
Answer
Answer
Since I installed MacOs 10.5 on my power pc, my scanjet 3570c stopped working. Then I downloaded the... (More)
Answer
HP Director Window Does Not Open in Windows XP. for more help please visit the below site.... (More)
Answer
Would like to scan in pure black and white to save disk-space. And all the "button-text"... (More)
Answer
HP scanner problem. I recently downloaded and installed a software upgrade for my HP Scanjet... (More)
Answer
1. When I scan a document to be saved as a MS Word file and then print it, I find that the printed... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Scanjet 3570 Flatbed...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
