Question about Acer 22" X223w LCD Monitor
I can not get the higher resolution on my Acer 22in X223W
I only have a VGA connection so how can I get the highest resolution (1650x...)?
  • mattqs Dec 25, 2008
    But the Monitor says it is a higher resolution that what the slide bar goes up to. Is that a video card issue I have?
  • 741 Answers
Monitors have Max resolution. What you call VGA is not really VGA, the standard for VGA is 640X480, SVGA is 800X600 and XGA is 1024X768. VGA and DVI are capable of different "GAs". Consequently you are not able to go beyond the capabilities of your monitor. Right-Click on a blank area of your Desktop and click on Properties. Then click on the Settings tab. Move the slide all the way to the right and that will be the maximum resolution for your monitor.
Posted on Dec 25, 2008
  • Randall  Trahan
    Randall Trahan Dec 26, 2008
    Yes, although unusal, as they normally match, your computer could do better with a different video card.
My acer x223w lcd monitor is flickering. When I change the resolution to 800 x 600 it stops. I have updated the driver and tried uninstalling and reinstalling.
hi, have you checked running the monitor on all the outputs? dvi? vga? flickering is caused most times by bad connections either in the video cable, or on the video board, or power board inside the monitor. i know those monitors pretty well, i'm willing to bet if you opened up the monitor and looked at the power supply board, you would probably find worn/blown capacitors. this could very well account for the flickering. electrolytic capacitors store power for parts of the circuit that require lots of power to run. when they go bad(overheat) they pop up at the top, sometimes leak a little fluid. they are replaceable, need to be soldered in, and you can find them at most electronic stores abundantly, but you should check everything else first, the video cables(dvi,vga) before opening the monitor.
Apr 28, 2010 | Acer 22" X223w LCD Monitor
I have a new Acer 22in v223w flickers
Check your power supply. IF it is through a UPS then try connecting directly to a main supply. If problem persists then look for a ACer service center immediately. There might be a problem with the panel.
Nov 30, 2009 | Acer 22" X223w LCD Monitor
How do you connect my pc to the hdtv?
First, with your pc connected to your current monitor, change the resolution to 800x600, turn off the pc, connect it to your tv via VGA or DVI, and turn on the pc, check your tv manual, seek the highest resolution supported and configure it ON PC. If the resolution is higher than your tv supports, will be no image.
Nov 29, 2009 | Philips 50PFP5332D 50 in. Plasma...
I have a x223w monitor that if you try to set higher than1280 x 768 it stretches eveything horizontally
Does your video-card allow you to set a resolution of 1680 by 1050?
(This is exactly 16 pixels horizontally for each 10 pixels vertically.)
This is the "native" resolution of the X223W monitor.
If not, pick a supported resolution that keeps the 16-to-10 ratio.
Sep 10, 2009 | Acer 22" X223w LCD Monitor
How to adjust LCD wide monitor to a higher
This error is typical of an incorrect video driver has been installed.
To check the installed video driver go to Control Panel - Display - Settings tab - Advance button - Adapter tab. This shows the adapter/driver. If it shows VGA graphics card or not the model of your graphics card then you need to download the correct graphic/video driver and install it. You will then able to configure the display at a higher resolution and at the highest color bit (ie 32 bit if there is sufficient video RAM installed).
Jul 29, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Refresh rate problem
It depends on your monitor. Some monitors don't support higher frequencies at higher resolutions. I wouldn't try to force it very much, as your monitor has built-in protection designed to stop it from operating at a higher frequency than it's capable. If you did find a way to work around that, you're likely to blow the monitor.
May 06, 2009 | Acer 22" X223w LCD Monitor
Hi There! My Acer x223w monitor is floating a "Input Not Supported" box that will not go away any suggestions?
The documentation for this monitor should list its supported resolutions, and you will need to attach another monitor that supports a greater (possibly lower or higher) range of resolutions and then set it to one of the supported resolutions for the monitor. The native resolution appears to be 1680x1050, although I cannot find online documentation directly from Acer.
May 04, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
New install Acer x223w monitor
You would only need that cable if the other end requires a VGA end. Happy Holidays
Dec 17, 2008 | Acer 22" X223w LCD Monitor
Acer 22" X223w LCD Monitor Logo
98 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
