Can we change the belt?
SOURCE: how do you thread an Elnita 140 sewing machine
It's easy! Start from the thread holder at the top and go left - hook it under the hook which is behind the round disc that the bobbin winds around, then forward down thru the tension, then under the straight metal bit that's below and slightly to the left of the tension, then up into the hook (slide it behind and then slide forward into the hook), then back down and flip it into the small hook (which is just under the 'straight metal bit' mentioned above) and thru the needle! :-) Hope that helps. The machine might be an oldie but it's a goodie! cheers Lynda
SOURCE: I need a new belt for my Elnita zz air electronic
try these two websites
sewingpartsonline.com
sewingmachineparts.net
SOURCE: I need a manual for an Elnita 120 sewing machine.
you can buy one from www.sewingmanuals.com via paypal. They have this model listed.
SOURCE: Where can I download a free user manual for an
Looked in several of the websites and can't find this one free but it is purchasable at
http://www.sewingpartsonline.com/instruction-manual-elna-250.aspx
I think this was one of the "made under licence for Elna" machines, not a Swiss made model.
Hope this is of some help to you.
SOURCE: I have an Elnita 140 sewing machine and would like
I am 90% certain that any low shank foot will fit this machine. Does your machine info plate say "made in Japan" or "made for Elna" anywhere? Is it about 30 years old? I'm pretty sure this was a "made under licence for" Elna Tavaro and that the machine is front loading bobbin model with pretty standard generic low shank feet; may be clip on too.
If this aligns with your machine, you should be able to buy low shank feet such as these at sewingpartsonline.com. Or if they are clip on, you can just buy the foot, not foot and ankle.
http://www.sewingpartsonline.com/low-shank-sewing-machine-presser-feet.aspx
The Elnita name was also used on Swiss made machines such as the 17 ZZ and I think used again recently however so it can get confusing. You could ask Elna themselves; start at www.elna.com, then go to your country, then "contact us" page to find a phone number of email. I have found that contacting the manufacturer/distributor in your country is often best. Or look at the images of the feet on sewingpartsonline, see if they look like what you've got on the machine now and take a chance on buying one or asking them if it would fit.
