Question about GE A830 Digital Camera
Write Peotect When I turn on the GEA830 this pops up and I can get it off or take pictures. WRITE PROTECT
  • jennykat123 Dec 26, 2008
    Just need a simple answer as to where to get a manuel
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • GE Master
  • 102,366 Answers
Take a look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Nov 26, 2010
Won't take a picture,write protect pops upon screen.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 28, 2011 | General Cameras
Olympua m 760 cant take pictures screen says write protect
Your memory card has been write protected.This can be very easily fixed.
  1. Turn off cam.
  2. Take out the mem. card. (it's probably located near the battery. press down on it and release it. it will pop out.)
  3. Slide the small switch on the side of the card to the position marked with an unlocked padlock.
  4. Put card back in and turn on cam. Done.
Apr 25, 2011 | Cameras
I just wat to delete certain pictures from my flash drive and it's not working. What should I do? the flash drive is called ATTACHE.
Hi there
You flash disk is write protected and you cannot delete or add new file from the flash disc. Just click right mouse and choose the program each text. One of those is the tools to unwrite protect the flash disk or if there is pop up software in your computer that use to write protect the flash disc.
I hope it helps you
Feb 20, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Hi... i have an Olympus Camera model no. E-P1 and i can't take picture because there's this "write protect" popping out on the screen... can u help me please on how to remove the "write protect" so i can...
This camera uses SD or SDHC memory cards. This type of card has a little switch on it that can write protect the card. Make sure that the switch is moved towards the edge of the card that has the contacts, not towards the middle.
Oct 20, 2010 | Cameras
What does write protect mean in the screen
most camera data cards have a 'write protect' slide switch on the side of them, which if it is in the 'write protect' mode, nothing can modify, or put new files onto it.
Basically what it's telling you is that you can't take pictures with that card until you pop it out and slide the switch to an 'unlock' or 'non-write-protect' position.
Nov 29, 2009 | Olympus FE-190 Digital Camera
42'' lcd turns on no picture/menu
Your tv is being attacked by electrical surges which seem very violent and has already damaged some logic controls. Please invest in a AC filter which will protect your tv from such spikes....... but first you need to get your tv serviced from the electrical damaged it has already suffered.
Nov 02, 2009 | Philips Televison & Video
How to turn protect off power shot s30.
You'll need to go into the review mode, hit menu, and then in the first category (top menu), scroll down to protect, and then hit "function set" to turn it off.
Sep 13, 2009 | Canon Cameras
Protect
The protect message indicates that a problem was found in the output stage of the amplifier. Unless this gets repaired, nothing will work. As a verification that the speakers or the wires are not the problem, unplug all of the speakers and try again. If protect still is displayed, the problem is inside the unit.
Dan
Apr 09, 2008 | Sony DAV-S400 System
Had loud pop and then no picture on the vizio 50in. plasma
TV was on with no picture problem. Left the room and when I returned the picture was very dim. Turned system off and turned back on. Picture didn't change, but heard a loud pop from the back of the TV.
Mar 25, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Static or popping sound
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jul 24, 2007 | Mitsubishi VS-45605 50" Rear Projection...
GE A830 Digital Camera Logo
Top GE Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a GE Camera Expert? Answer questions, earn points and help others
