Question about Williams 3003622 Ceramic Wall Mounted Panel Heater
Williams 3003622 Wall Mounted Panel Heater Draft Blows Pilot Out.
Our recently purchased wall heater's pilot light blows out. There is a draft which makes it difficult to re-light. Does anyone know how to fix this problem? Thank you.
Yes. open cover, set to pilot and push in then light with a long nosed butane lighter like the ones used for lighting stoves. Hold pilot in for a few minutes, then close pilot cover and turn pilot knob to on position. that should take care of it unless you need a new coupler. good luck as the couplers go out on these heaters prematurely.
Posted on Mar 10, 2009
Where is the orifice on a williams wall gas heater 290622
Where the pilot is unscrew pilot tube from pilot assembly and inside there it is
Feb 26, 2013 | Williams (5009622) Ceramic Gas Wall...
It is a Williams circa 1985 gravity direct vent wall furnace mdel 30DV 5, 30,000 btu. Light pilot OK. Heat on OK. But when heat not called for (several hours) pilot must go out. There is a small penny...
That hole should only be a problem, if a strong draft comes thru and blows the pilot out. But that hole may also be for match lighting the pilot in an emergency. The older models like yours, had that feature. Check it closely, before you decide to block off the hole.
Hope this helped you.
Jun 19, 2011 | Williams 3003622 Ceramic Wall Mounted...
Hello i have a williams wall Furnace model#25-35-50. I need to know if its a base board heat and also if you could tell me which wires are which. 1 red and 1 white
What you have is a Direct Vent, Gas WALL Heater. It is normally mounted about 6" off the floor on an exterior wall (since it has to be direct vented out). Not sure what the red and white wires are for, but suspect it's for the optional thermostatically controlled blower connection.
In any event, to help you install this heater properly, I have included a link to the Owner/Installation Manual, which should provide all the information you need to complete the installation correctly.
http://shopfnc.com/pdffiles/williams2man.pdf
You can download and print the manual for future reference.
Feb 26, 2011 | Williams 3003622 Ceramic Wall Mounted...
When burners come on , the flame floats around for about one minute , then cuts out the burners and pilot.
It appears that you have a draft problem with this heater. too much air causes the flame to lift off the burner or too much gas pressure could cause the same symptoms. check your draft at your burner first just to make sure that it's not open too wide. unfortunately the gas pressure has to be set with a manometer to get the correct pressure. 11.7in. wc for LP gas and 3.5in. wc for natural gas.
Nov 27, 2010 | Williams 3003622 Ceramic Wall Mounted...
I have no instructions for re-lighting my furnace's pilot light. Can you help?
Instructions for lighting the pilot can be found on page 10 of this Installation Manual.
Here is link on How to Light the Pilot on a Water Heater. I realize this is not a water heater you are working on, but the setup is very similiar the link has a couple of videos that you might find helpful. :-)
Apr 23, 2010 | Williams 3003622 Ceramic Wall Mounted...
Williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
Re Williams 3003622 Heater Please advise how to ignite pilot light.
You will first need to turn the control knob to pilot. Then depress the control knob button and hold it. Then press the push button piezo igniter several times until pilot lights or open pilot inspection cover and manually light pilot with match/lighter. You may need to hold the control knob for at least a minute. Then release the control knob and if the pilot stays lit then turn the control knob to on. If it does not light then repeat the process again.
Oct 27, 2009 | Williams 3003622 Ceramic Wall Mounted...
Need to turn on pilot light of Williams 3003622 serial # 400518D
Find the gas valve and turn it to pilot. (Or light) Use a long reach lighter. Light the lighter and press the knob in. Light the pilot and continue to hold the knob in for about 15 seconds. When you release it, the pilot should stay lit. If it doesn't, you need a new thermocouple. That's the small tube that the flame touches when the pilot's lit. They're inexpensive and usually not too hard to replace.
Jan 30, 2009 | Williams 3003622 Ceramic Wall Mounted...
Williams 3003622 Ceramic Wall Mounted Panel Heater Logo
865 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
vance jones
Superior Maintenance
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
