Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Initial set-up not working
We have a new HDMI flat screen Phillips TV with a set top cable box, HDMI capable, with cable wire connected to the set top box and HDMI cable from the set top box to the TV into HDMI #1 port on the TV. All we have on the screen is "channels not available". So I disconnected the HDMI cable from the box to the TV and connected a coaxial cable from the set top box to the TV, and we got a picture (but not high definition). Help please!
  • 4402 Answers
no this is what you need...
Convergence amp ic bad
or send it in for repair here
Posted on Feb 07, 2008
SOURCE: dvp5960 hdmi set up issues
You can disable the digital audio output in the audio tab at the setup menu.
Posted on Jul 13, 2008
  • 38 Answers
SOURCE: broke the piece where the cable wire goes in...what's it called?
Do you have a cable box or satilite box? You can come out of the box with the video output and into the tv and use it on video1 or whatever...and use it that way. Also a vcr will work the same way. Then your using the t.v. as a monitor and changing stations with the box. That's an easy "get-around" You just have to be careful when fixing the broken connector with a substitue cable. Some antenna inputs are isolated from ground, so if you use another cable, you will blow out the T.V. The isolator is usually a small 1 inch square box the connector came out of, then a small cable attaching to the tuner. If the connector was attached to the tuner itself, then you need a new tuner or a repairman to solder a new connector on. Don't try and solder one on yourself. I've yet to see that work be anyone other than a repairman. You could change the tuner yourself if you can solder somewhat well. Good-luck.
Posted on Dec 22, 2008
  • 19396 Answers
SOURCE: Phillips 55'' rear projection tv model #55pp970104
That is a convergence problem, it may be because of a faulty defective IC.
Posted on Feb 09, 2009
  • 67 Answers
SOURCE: Recording HD channels
well you would need to hook up cable box to dvd recorder. the only draw back first off is one you cannot get hd onto a dvd. you can down scale and it will seem a little cleaner than standard def but of coarse it will never be high def. I'm not to familiar with the motorola boxes but if they offer dvr's in your area i would suggestgetting one you can record all channels then afterwards transfer them to a outside device. but as i said before high def cannot fit onto a dvd unless you plan to copy one movie to 6-7 disc. Just keep in mind a standard high def channelcan only fit 2 max on one freq due to the amount of data transfer as opposed to 10 to 12 standard def digital channels
Posted on May 08, 2009
My tv model magnavox26mf231d/37 shows hdmi is disabled and the hdcp authorization failure.
This could be a problem with the cable box or other set top box and not the TV. It's known to happen with Samsung cable boxes from Cablevision.
First try resetting the TV and set top box by unplugging both. Remove the HDMI cable from the TV and the set top box. Reconnect the HDMI cable. If you are using a Redmere or similar HDMI cable, make sure that the end labeled TV is connected to the TV's HDMI port. (These cables have additional electronics and are not reversible.) Connect the power cord to the set top box and wait 30 seconds to a minute. Then plug in the TV. To ensure the set top box does the correct handshake with the TV, turn on the TV first and set it to the HDMI input. Then turn on the set top box. See if this fixes the issue. (On some cable boxes, this can be a temporary fix. You may need to have the set top box replaced.)
If the above steps don't help, try a different HDMI cable. If that doesn't solve the problem, then the set top box is faulty.
I hope this helps.
Jan 10, 2015 | Televison & Video
Television say check signal cable . I have a scientific atlanta cable box.What do I do?
How is the TV connected to the cable box (HDMI, component video, etc.)? Make sure that the cables are securely connected and that the TV is on the correct input. Try swapping the current cables for new ones. (The HDMI cable has come loose on my entertainment system at times.) If you route HDMI cables via a sound receiver (cable box -> receiver -> TV), try a direct connection to the TV.
For my TV, I have to turn on one set-top box before I turn on the TV to get the signals to correctly synchronize. (Try turning off everything connected to the TV and then turn on the accessories first. Then turn on the TV.) For another set-top box, it needs to be turned on before the TV. (So try both options.)
Make sure that your set-top box is on and try a different TV or input if possible. If a second TV doesn't work with the box, contact the provider and check for a service outage. (Also try a different set-top box (like a blu-ray player) to check if it is the input on the TV.)
Note: I've had mice or other things damage wiring; this takes out the cable and phone lines. If this is outside damage, your service provider should repair the damage for free.
I hope this helps. Please add a comment with more information about your TV and the connections that you are using for additional support.
Apr 25, 2013 | Televison & Video
Flat Screen Insignia TV picture too big? How to adjust picture size?
When the picture is too large there are three possible solutions at least.
Starting with the simplest two: There are buttons on the remote controls (cable/satellite and television) that control the picture size. On the cable remote it is usually on the bottom, and it says hd zoom. Press it and it will size the picture down for you. On the television or satellite remote it might say view mode, picture mode, format or aspect.
Now, the more difficult solution if the above doesn't work: The settings might not be right in the cable box/set top box. If the television is a 720p television, make sure the cable box/set top box is set for 720p and not 1080i even though they're the same (yes, yes I know). Also make sure you are not connecting a cable/set top box to the coaxial rf input when you have the capability to connect to a component or hdmi cable. I hope this helps.
Dec 01, 2012 | Televison & Video
How do i connect cable to this tv
RCA Tru Flat has one of the best pictures for a digital flat screen. This exact TV is my bedroom TV in my home. As for the cable, you can run either a standard 75ohm coax cable or AV wires from the cable box to the back of the TV. Hope this helps.
Mar 09, 2011 | RCA F27678BC 27" TV
I connected the cable box to my LG tv with new HDMI cables and the picture is noticeable smaller than the size of the screen. Before, I had the cable from the wall connected directly to the tv and the...
Your cable box and TV are set to different resolutions. Check the setup on both and make sure everything is the same (ie 720p to 720p or 1080p to 1080p) Make sure your cable box can give you 1080p (Nice set, BTW!!). HDMI is supposed to automatically take care of the settings, but it does not hurt to double-check.
Depending on the manufacturer of the cable box, there may be screen setting for "letterbox" which should be selected.
Some TV channels, when redirected through a cable box, simply will not display full resolution (1080p) programming. Your cable TV provider can tell you which channels are displayed in high resolution.
Finally, make sure your cable provider gave you the correct box. Older boxes are not capable of providing 1080p resolution, and since you own a 1080p set, you deserve nothing less!
Jan 30, 2011 | LG 42LD520 42 in. HD-Ready LCD TV
CABLE BOX HDDVR IT's NOT WORKING WITH HDM1 in put. I have to use av1 source with 3 wire cable. Comcast tech saying it is tv problem.
I am not with Comcast, but rather a much smaller family owned cable company.
You can check the user settings of the box to verify it is in the HDMI mode. Depending on what type of HDDVR you have that is.
For Motorola 62XX and 64XX models follow these steps to check.
1. make sure that your HDMI cable is connected to both the TV and the cable box.
2. Turn TV on, and verify it is on the proper input.
3. Turn cable box off.
4. Press menu button on remote or front of cable box.
5. A user settings menu will appear on the screen.
Note: if it did not appear you may have to connect another type of cables to continue.
6. Information displayed should be set to what your TV set is capable of. Most HDTV's will be set to the following:
7. If you see additional HDMI settings as the forth item your TV and cable box are communicating across it, if not try unplugging both the TV and cable box and/or replacing the HDMI cable. Enter the additional settings by pressing the right arrow on the remote.
8. Change DVI to HDMI.
9. Press power to exit the user settings menu.
10. Turn cable box on, and switch TV to HDMI input if not already on it and see if the picture is coming in now.
Note: if you think that you messed up in the user settings you can always restore default settings by following steps 1 through 4 then press up arrow once and right arrow once.
I hope this helps you cable customers, as we appreciate your business unlike Dish and Direct!
Jun 18, 2010 | Philips 47PFL5704D 47 in. LCD TV
I have a Phillips HDTV model #42PF7421D/37. When
Try another hdmi wire. Physically look at the hdmi port and see if there is damage done to the port. Change the source. IE another cable box, xbox 360 dvd play etc. If all else fails, change SSB or Scaler. Depending on the set. It'll be one or the other. I don't have my information with me at the moment to distinguish which one you'll have.
Dec 08, 2009 | Philips Televison & Video
Bad picture
  1. Hello boss, here is d way to make best use of it.
    step 1.Make sure ur LCD or Plasma HDTV has an HDMI port. Hopfuly u bought 1 with it, if not, you may be stuck using component cables. Not bad, but not he best. Component cables change d digital signal frm the cable box into an analog signal. This conversion allows for signal degradation. U want to keep the digital signal transmitted frm the cable company 2 go directly into ur HDTV. An HDMI cable will provide u wid this capability n with d clearest picture.
    2. Make sure ur cable box has an HDMI port. Most cable companies do not offer a cable box with an HDMI port on the initial install. You may need to upgrade by calling your cable company and asking if they have a cable box wid HDMI capability. Ask them 2 send u 1.
    3.Purchase an HDMI cable. TIP - The longer d distance between the cable box n d HDTV, the better d quality HDMI cable. This is due to degradation of d digital signal over long distances, wiz could result in a poor quality picture. ne distance over sixteen feet should be compensated 4 by using a heavier gauge HDMI cable. Oh yea, don't get taken by buying the most expensive cables. From what I have read, companies are cashing in on this relatively new technologymag-glass_10x10.gif. I bought my "gold-plated" HDMI cables from an Ebay Store, "eforcity" for about a quarter of the price found at the local electronic store. Connect one end of your HDMI cable into the HDMI (out) port on the back of your cable box and connect the other end to the HDMI (in) port on the back of your HDTV.55
    Read the instructions that came with ur new HDMI compatible cable box. These instructions will explain the download process the cable box needs to go through before use and the Setup Wizard that will program the cable box to send the correct picture format to your HDTV. If u did not get instructions, u can get them at the cable box manufacturers website. Scientific Atlanta's website: Adjust video, audio, and screen settings to ur liking. The explanation for these settings can be found in ur HDTV's user's manual.75.Push ur "source" button on ur remote control or HDTV n select HDMI. Tune to a Hi-Def channel. Most Hi-Def channels r in the 700 channel range. Check cable company listings 4 d specific channels.
  2. Have a nice time!!
Aug 19, 2009 | Sharp LC46SB54U 46 in. LCD TV
I have a 47'' phillips lcd flat screen,will my tuner work without using cable box(timewarner) and still pickup all the channels
If the TV tuner has digital connection with HDMI, or th white red and yellow connectors for RCA cable, it will work with the new TV.
If the tuner has only coax round antenna-like connector, then it will not work with TV tuner.
Many new TV also do not have scart cable connector, but adapters Scart to RCA are available.
May 05, 2009 | Philips Televison & Video
I cannot get a signal on my Phillips 50
if you haven't unplugged the unit for 30 seconds, try that. otherwise, if that doesn't help, probably a board needs to be replaced. call phillips for service.
Mar 14, 2008 | Televison & Video
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
