Question about Generac Guardian 100 Amp Transfer Switch with Service Disconnect NEMA 3R
Transfer switch will not switch back to utility
This morning I heard the standby generator running at my shop. We have had no power outage so I went to investigate. I found the transfer switch in the generator position. Proper utility power was present at the main panel and into the transfer switch. When I tried to manually transfer it back it sounded like it was shorting out and would not go back to utility. When I turned the breaker off at the generator I was able to switch it to utility but as soon as I turned the breaker back on (at the generator) the transfer switch went back to generator. While it is in generator mode everything worked correctly, as it did in utility mode. The unit is a 7 kw generac guardian with the supplied 100 amp transfer switch. It is about 2-3 years old and has never experienced a problem before. There is no obvious damage inside the transfer switch. I have looked for a troubleshooting guide and schematic but have not had any success yet. I also have a generator on one of my restaurants (60 kw) and this same thing happened and I had to replace the switch. I'm hoping its something as simple as a relay, that is why I have presented my question here. Thank you in advance, Walter Wiseman
  • 53 more comments
  • Anonymous Mar 11, 2014
    heating blend door actuator
    microwave does not work. Lock sign came on. How do I turn it off.
    What is the value of "c" in the quadratic equation 3x 2 + 5x + 7 = 0?
    will not heat jenn air W3400B
    manual for a 1990 Yamaha Xt600 enduro
    The digital readout lights up with "dashes" but will not operate any further ??
    my Compaq computer wont let me login to my gmail account it told me my cookies are disabled but they are enabled
    2010 buick lacrosse how to chang door mirror bulb signal nor light come on
    fabric is getting stuck in machine under pressure foot and bobbin thread is tripling
    the coils all have the same resistance. it seems at higher rpms the cylinders do fire, and on deceleration it backfires. lower rpms no power but higher it kicks in. I was thinking timing. Just got bike.
    241 paper jam
    My 2001 cavalier is not shifting out
    sometimes the air conditioner does not start working. later down the road it will start working.
    need to find out d correct torque spec an thightin sque for cylinder head
    volvo xc70 abs code 0094
    stop feeding through by pass tray lexmark T654
    tappets rattle when car is started
    How do you remove the head light lens cover
    experia phone does not warn for incoming messages
    On my 1999 Saab 9-3 bright lights won't stay on but will flash on
    change rear axle seal
    I fogoted my passward so haw can i remove it is a nokia asha 302
    I just bought a Stalwart safe. I have all keys and paperwork. I can open the safe just fine. However, I follow the instructions to change the factory code and it does not work. I cannot find additional or corrected instructions anywhere.
    printer error has occurred, turn off power and power back on C000
    photosmart c6180 displays un able, to copy,recieve faxes,or print
    how to get a radiator out of a 2002 ford taurus
    exhaust fumes in car
    Salad spinner assembly
    amp power
    Maintaining the keurig coffee maker
    How to get chrome shield off tailgate
    2005 saturn ion shift soleniod
    Where do the scanned documents go to on the pc.
    facebook home login page
    it is the oldest iphone and its been dropped a few times and I really need a new phone but I also need the text messages off of it pictures, and contacts what can I do ? I have an icloud account. Please HELP!!!! Thanks
    How to install an acer aspire S3 391 keyboard
    Hi, how would I get rid of a bottom purple border on the image of my sharp XG-C465X projector? thanks mike
    Electronic control module stopped responding
    The car stalls out when driving it 3-6 miles down the road.. The car starts right back up but very intermiton on when it stalls and when it doesn't. This we bought 2 weeks ago so have no ideas.
    key and key fob locked in vette
    Ice maker makes ice, but will not dispense through the door
    PASSENGER DOOR HANDLE BROKEN ON SIENNA 2003
    CANT FAX NOTHING OR RECIVE
    Change brushes
    how do I trouble shoot?
    where is the brake fuse located at on a 2000 range rover
    I can't get my audio files to download from my olympus DS2300 to my laptop (windows Vista). I have the device manager screen, I can select the file, click download by nothing happens?
    My element light won't shut off
    2006 chevy malibu winshield wipers will not shut off
    where is the temp sensor located for replacement
    Headlights problem of the 2001 Dodge Dakota
  • Anonymous Mar 12, 2014
    I have tested the switch and the motor. both are good
    the end of the throttle cable of my 1996 dodge pick up broken
    I have a HTC phone and wish to download some photos from it onto my computer, what do I need to do it?
    There is a clacking sound when I accelerate and when I start the car. Help with my Mazda Tribute 2005. I put the key in the ignition as the car tries to start there is a clacking or ticking sound coming from the engine, this is also happening when I depress the accelerator
  • 10,594 Answers
I do not have its schematics but theory says circuit which is responsible to energize relay up to utility supply is not working and auto switch shift to generator mode.
I would recommend to replace it as well because its sensitive part and hard to repair.
Thank you
Posted on Dec 25, 2008
    Sergeant:
    Novelist:
  • 327 Answers
Its the problem of the switch and it has to be replace in such cases to make it proper.it is necessary to replace the switch.
Why wont my transfer switch change back to utilities position when the power is restored?
It depends on the brand of switch and generator. A Generac has its brains in the generator control board, others in the switch, what brand of switch please?
Aug 20, 2014 | Electrical Supplies
Coils on transfer switch got fried when utility came back what could have caused this
possible failure of a relay. contact generac,sometimes they will accomodate you with new parts
Oct 08, 2012 | Generac Guardian 200 Amp Transfer Switch...
The generator doesn't turn off after transfering power back to the utility
The transfer switch is responsible for starting / stopping the generator. Check your auto - start circuit. It is 2 wires that go between the genset and ATS. They are generally normally open. When the genset is to shut down this circuit needs to change state.
Jul 09, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
I have a Briggs & Stratton Automatic Home Generator 7 kW, Model# 40301. I had it installed by an electrician. Who also installed Briggs & Stratton Transfer Switch 50 Amp. The problem is the...
It sounds like the mains sense wire is disconected from the control panel or the run wire is not being cut by the aux contact on the transfer switch.
Is the transfer switch manual or motorised?
Feb 15, 2011 | Briggs Stratton 7,000 Watt Automatic Home...
What is the proper proceidure to set exercise timer on a briggs generator model # 01938 and what year was this model manufactured? thank you
http://www.homegeneratorsystems.com/service_support/manuals/index.cfm?rd=1
This link will take you to their site where you can download their manual.
Setting Exercise Timer
The Home Standby Generator is equipped with an exercise
timer that will start and exercise the system once every
seven days. During this exercise period, the unit runs for
approximately 20 minutes and then shuts down. Electrical
load transfer DOES NOT occur during the exercise cycle
(unless an utility power outage occurs).
A switch on the control panel is labeled “Set Exercise”
(depicted on page 10).The specific day and the specific time
of day this switch is pressed is programmed into the
control board memory.This date and time is then used to
automatically initiate the system exercise cycle.
To perform the Set Exercise procedure:
1. Choose the day and time you want your Home
Standby Generator to exercise.
2. On that day and time, set the AUTO/OFF/MANUAL
switch to OFF.
3. Press and hold down the “Set Exercise” switch for two
seconds.
4. Set the AUTO/OFF/MANUAL switch to AUTO.“Set
Exercise” is complete.
For example, if you press the “Set Exercise” switch on
Sunday morning at 10:00 AM, the unit will run an exercise
cycle the following Sunday at 10:00 AM (+/- 1/2 hour).
NOTE: “Set Exercise” will only work if the unit is in the
Automatic mode and this exact procedure is followed.The
exerciser does not need to be re-set if the 15 Amp fuse is
removed or changed.The exerciser will need to be re-set if
the 12 Volt DC battery is disconnected.
If you want to change the day and time the unit exercises,
simply perform the “Set Exercise” procedure at the exact
weekday and time you want it to take place.
• To prevent possible injury that might be caused by such sudden
starts, always set the AUTO/OFF/MANUAL switch to OFF.
• Remove the 15 Amp fuse before working on or around the
generator or transfer switch.
Nov 12, 2009 | Briggs & Stratton 12,000 Watt Bi Fuel...
Same problem, generator kicked in after power outage,
At the point the transfer switchis suppose to transfer put a dc volt meter across terminals 23 and 194 in the transfer if you do not show 12VDC. Then you have a relay hanging upon the PCB board in the generator, need to replace board. If you are showing 12VDC and the switch is not transferring the problem is in the switch itself.
Sep 08, 2009 | Generac Guardian 100 Amp Transfer Switch...
The transfer switch should transfer back to utility within about 30 sec. after utility is restored. While waiting for the transfer switch to switch back to utility volatge. Check for DC volatge across wires 23 and 194 in the transfer switch, if you have battery voltage(12-13.5 VDC) then you you probably have a stuck relay on the PC board in the generator. The board needs to be replaced. If you don't have battery voltage across these terminals then your problem is actually in the transfer switch.
Jul 31, 2009 | Generac Guardian 0A18010 - battery...
Generac Guardian 100 Amp Transfer Switch with Service Disconnect NEMA 3R Logo
211 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
