Question about Sony VAIO VGN-S460 Notebook
How to replace fan for VGN-S460
My laptoip fan makes too much of noise and I need to replace it. I havea spare fan and looking for step by step instructions on how to replace it. I have opened my laptop numerous times to replace harddisk, memory upgrade etc. Any help is greatlyy apreciated.
    Scholar:
  • 141 Answers
Posted on Dec 25, 2008
I plan to increase memory for my VGN-S460. What kind? How big? UP to 2G is correct?
Try searching on http://www.kingston.com - you can look up your computer and they'll tell you how much RAM it will take and what type.
Jan 12, 2011 | Sony VAIO VGN-S460 Notebook
Fan grinding sound
Fan grinding sound usually comes from the fan that sits atop of the CPU. Get the CPU fan replaced cause the bearings are going bad.
May 07, 2010 | Sony VAIO VGN-S460 Notebook
Sony vaio fan is making a grinding noise, how can i fix this?
The sony VGN-S460 seems to have an inherent problem with their cpu fans. It is apparent that the fan uses a ball bearing system which over time becomes worn and causes the grinding sound.
The only solution is to replace the entire fan assembly as they are inseparable.
Nov 15, 2009 | Sony VAIO VGN-S460 Notebook
I have the same problem for Sony VGN-S460 heatsink fan problem
I trust that you have purchased the entire fan assembly as they are inseparable from the heatsink. You must disassemble the entire laptop in order to remove the fan assembly. they are two screws that are below the motherboard that must be remove in order for the fan assembly to come apart.
If you cannot achieve this yourself, or lack confidence in your ability to rebuild the unit after, you can send the unit to us at www.cowetacomputerstore.com and we will accomplish the desired outcome. We have worked on this system resolving this very issue.
farewell
Oct 05, 2009 | Sony VAIO VGN-S460 Notebook
Sony vgn-s460: screen blinks, fan runs very loud
Possible clock timing of CPU is wrong. Is it two fan on this laptop? Maybe one is not functioning. Plus check your power supply if gives correct power!.. If none of this , it comes to the MB and possible a CAPS making problem. Need expert.
JMC
Aug 06, 2009 | Sony VAIO VGN-S460 Notebook
Have vaio VGN-S460, window 7. Can't get internet
Windows 7 is still a beta and Sony probably doesn't make drivers yet for the network adapter on that computer. You might be able to install the windows vista or xp drivers and that may work. You might have to manually install these drivers, however.
Jul 09, 2009 | Sony VAIO VGN-S460 Notebook
I need steps to replace Fan for my Sony VAIO VGN-S460
the fan is screwed together with the motherboard, the only way i figured is to separate it is completely unscrew the motherboard, cd drives.....then unscrew the fan from the bottom side of the motherboard....
i took the fan out just today, wantted to add some lubricating oil to it, but then can't manage to separate the blades & expose the centre
how much did the replacement fan cost? i am in canada, not even sure sony stores here have it.
Dec 25, 2008 | Sony VAIO VGN-S460 Notebook
Noisy fan--sony vaio vgn-s460
then if that is the problem to your pc then turn your pc upside down and dissassemled the screw at the back then your keyboard should be lift up slightly and if you can not do that on your own try to contact someone in that field to help you but just for you to tell the person that you know what is wrong w2ith the pc the person should try and check if there is anything too close to the fan that the fan is touching and if there is nothing the fan is touching and the noise continue then change the fan with a new one. bye any question again.
Aug 25, 2008 | Sony VAIO VGN-S460 Notebook
VAIO VGN-S460
check adapter output also may be problem with dc socket on laptop loose or somthing.
Apr 11, 2007 | Sony VAIO VGN-S460 Notebook
Sony VAIO VGN-S460 Notebook Logo
448 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
