Question about Kenmore 95592 / 95594 / 95595 / 95599 Electric Kitchen Range
Fp came up on my stove
My kenmore stove stop working in the middle of cooking christmas dinner and I cant find my handbook it came across a code of f9
5 Suggested Answers
Bgillespie
  • 89 Answers
SOURCE: Oven pilot light will not stay lit on Garland 6 burner, double stove, salamander commercial in home
Use a needle right where the pilot flame comes out. Should do the trick. GOODLUCK!!
Posted on Dec 16, 2007
SOURCE: Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Posted on Dec 26, 2007
SOURCE: Stove elements won't turn off
replace switch for that burner
Posted on Jan 17, 2008
SOURCE: jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Posted on Jan 16, 2009
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
How do i change a whirlpool model wbp88800 burner control
Unplug stove. There should be two screws under edge of the cook top. You need to open oven door to get at them. Remove screws, lift cook top up at the front and prop it up. There will be two or three screws with spring clips holding the burner to the cook top. Unplug the connections, remove screws, remove burner. Install in reverse. I did this at Christmas just in time for dinner. It takes about ten minutes.
Feb 06, 2015 | Whirlpool Kitchen Ranges
I'm in the middle of cooking dinner and I got a f3 e2 error and the oven locked...how do I get my dinner out? My husband is an elevator mechanic so he's handy...we turned off the breaker to quit...
That code refers to the oven temperature sensor sensing a too hot oven. I suspect what you did to quite the cleaning cycle should help once the temperature cools down the door should open. I am a little confused, did you set the oven to clean while your cooking, or did it do this on its own, or was it preset and yopu forgot it was set to clean? Your temp sensor may be going bad if it just detected a too hot oven while your cooking. If it started cleaning then it may have gotten too hot and this is the safety device to prevent it from overheating. it sounds like it is trying to self clean, its essential that you find the error code sheet, stuck in the stove or oven cabinet somewhere, also check your range settings so that it is not set to auto clean.
Jun 28, 2011 | Ovens
Was cooking dinner, and in the middle of dinner, I walked away and heard a popping sound. I checked the oven and it stopped working. My husband turned the breaker off and back on and the stove top works...
It sounds like the bake or broil element went bad and they will make a popping sound. Usually it is visible on the element that it is bad. You may have to measure the element. It should measure 8-30 ohms if good. If there is no visual sign and you are unable to measure elements keep oven off until a repairman comes. Please rate me after reading this.
Dec 13, 2009 | Kitchen Ranges
Dec 25, 2007 | Kitchen Ranges
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Kenmore 95592 / 95594 / 95595 / 95599 Electric Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Sal De
Marvin
Marvin
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
