Question about Kenmore Oasis HE 27082 Top Load Washer
How do I get pennies out
I have pennies stuck in the bottom where the pumps connects.  How do I get them out?
  • jaimeepearlm Dec 25, 2008
    They are stuck in the molded plastic
    Genius:
  • 2,920 Answers
You will have to pull the pump off where it connects
Posted on Dec 25, 2008
  • Ronnie Houston Dec 25, 2008
    you will need to take that whole part of the system loosed so you can get to the pennies
Something stuck in the cd player, how do i fix it?
Take the outside cover off the cd player and see if you can get the pennies out they could be causing something to hang up or not read disc
Sep 29, 2012 | 2006 Ford Freestar
I have a Fisher Paykel GWL15 and it kept on getting stuck on the rinse cycle. Today it completely stopped in the middle of a load and will not power back on. I trouble shot all the possibilities and the...
When the penny jammed the pump the unit will stop working, when the pump cools down it should start working again, unless you have had this issue for a while. I would just replace the pump and install the fuse that comes with the pump now completely. You should not have any more issue if you complete the instruction that come with new pumps today.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 22, 2011 | Fisher Paykel EcoSmart GWL15
Have Maytag 8700 washer and have replaced the drain pump, but still will not drain.
You probably have something stuck in the drian hose itself. Have seen many that a ball of lint with a dime,penny or five cents stuck in the middle of the hose.
Jul 03, 2011 | Washing Machines
Fisher & Paykel GW612 gets to rinse stage and doesn't drain properly. The drain pump gets rid of some water then cuts out for a couple of mins, then starts again. It does this 3 times before...
I recently had a similar problem and here is how I fixed it: Locate the drain pump. Connected to the outlet of the pump is a black rubber tube approximately 6" to 10" long and 1/2" in diameter. This tube is connected to a valve. The clamps holding the tube in place can be removed by hand. Take the clamps off and remove the tube. I found a penny stuck in mine near the valve end. How a penny made it through the pump and most of the way through the tube, I don't know, but I removed it, and the washer works as good as new. You might as well put a few drops of oil on each of the pump bearings while you are working on it.
May 14, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Why do we keep getting pennies in the drain pump? We search our clothes carefully but apparently it is only pennies. Is there a possible broken screen?
no broken screen when washer goes in to spin the pennies move up the inner tub to the outer tub to the pump inlet remove pennies from close
Oct 14, 2009 | Maytag Bravos MTW6600T Top Load Washer
97 blazer won't start. car had new fuel punp and filter inside tank replaced, ran for awhile cut out and now won't get any gas. have listened at tank, pump is working. what can i do next
This sounds very similar to a problem I had...after replacing the fuel pump, I still had the same problem. Turns out, there's a switch at the bottom of the steering collum that was messed up. It was about $300 to get fixed, but worth every penny!!
Apr 14, 2009 | 1997 Chevrolet Blazer
WATER PUMP ON DUET
Was easy to remove clamps with a pair of Channel-lock pliers
Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
3.5 super capcity front loader
The drain pump had $0.86 in it (three quaters, a dime and a penny), a gaurdian angel medal and a sock stuck in the pump inlet. It was easy to fix by removing the lower fromt cover (two srews), taking off the spring clamp on the hose at the front of the pump and removing the rubber trap hose thingy.
Oct 07, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Pennies
penny trick is when u tape 3 pennies together and put them on bottom of memorychips on the mother board total of twelve pennies for four memory chips on bottom this is done to fix the 3 red lights just a temp fix but i would recommend doing the x-clamp replacement better success
May 25, 2008 | Microsoft Xbox 360 Console
Kenmore Oasis HE 27082 Top Load Washer Logo
41 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
