Question about Frigidaire GLEQ642A Electric Dryer
Samsung DV448AG Electric Dryer  gave it to my wife for xmas and power everything works but there is not heat comming from the dryer
  • 184 Answers
SOURCE: Dryer doesn't heat.
THE FIRST THING TO CHECK IS YOUR POWER. THE OUTLET HAS TWO ANGLED HOLES THAT SHOULD TOTAL 240VOLTS ACROSS THEM. THE L SHAPED HOLE IS THE GROUND AND THERE SHOULD BE 120VOLTS FROM EACH ANGLED HOLE TO THE L SHAPED HOLE. THE DRYER'S MOTOR ONLY RUNS ON 120 VOLTS ( FROM ONE ANLGLED HOLE TO THE L SHAPED HOLE). THE HEATING ELEMENT CIRCUIT RUNS FROM ONE ANGLED HOLE TO THE OTHER(240VOLTS)
THE DRYER WILL RUN BUT NOT HEAT WITH ONE SIDE OF THE CIRCUIT BREAKER TRIPPED.
IF POWER IS O.K., THE NEXT THING TO DO IS PULL THE BACK PANEL OFF OF THE DRYER. THE HEAT ELEMENT IS IN A BOX ON THE RIGHT SIDE WITH TWO RED WIRES GOING DOWN TO THE BOTTOM OF IT. IF YOU HAVE A METER, CHECK FOR 240VOLTS AT THE TWO WIRES ATTACHED TO THE BOTTOM OF THE HEATER. IF YOU HAVE
240VOLTS THERE, THE HEATER IS BAD. IF NOT, THE ROUND ITEM NEAR THE BOTTOM IS A HIGH LIMIT THERMOSTAT. IF YOU HAVE 240VOLTS AT THE TWO TERMINALS ON THE THERMOSTAT, IT IS BAD. PART #
279769 COMES WITH THE HIGH LIMIT THERMOSTAT AND THE THERMAL FUSE FOUND AT THE TOP OF THE HEATER ASSEMBLY. CHECK THE THERMAL FUSE THE SAME WAY.
IF IT IS BAD, YOU WILL SEE 240VOLTS ACROSS IT.
IF ALL THOSE COMPONENTS ARE GOOD, IT COULD BE THE TIMER, TEMP SELECTOR SWITCH, OR THE MOTOR'S CENTRIFUGAL SWITCH. YOU WOULD HAVE TO READ THE WIRING DIAGRAM INSIDE THE CONTROL PANEL TO CHECK THOSE ITEMS.
Posted on Apr 03, 2008
Illeagle
  • 525 Answers
SOURCE: how do you replace the
The fuses or breaker is located in your homes fusebox. An electric dryer requires 240 volts and 2-30amp fuses, or 1-30amp breaker. Locate your fusebox and determine if you have fuses or breakers. If fuses, then I recommend changing both 30 amp fuses to eliminate any possibility of being wrong. If it uses a breaker,(If not labled, look for the number 30 on a breaker). Flip the breaker to the OFF position, then back to the ON position. Repeat this action if there are more than 1-30 amp breakers and your dryer still doesn't heat.
Posted on May 26, 2008
rdial54
  • 14 Answers
SOURCE: Kenmore dryer (electric )
replace heat relay
Posted on Sep 07, 2008
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
  • 1531 Answers
SOURCE: have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
Posted on Sep 17, 2009
Kenmore dryer will not heat up
I couln't bring anything up using the model number you gave, but generally an electric dryer will have heat if the heating element gets the signal from the switches and it is not open.
If everything works beside the heat, then I would make sure that the heat selector switch is operational and if it is then to replace the heater element.
Jun 17, 2011 | Kenmore 600 6963 Electric Dryer
The dryer the cheapest electric dryer made by roper just blows cold air duc is clear filter is clean everything works should i start by checking the heating element or coil hunter19-46m gave me good...
well, may be the heating element: here is the website. maybe something else like the thermal fuse, Good Luck Tim:
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Apr 17, 2011 | Dryers
Apparently the heat element has gone bad. Everything works, but no heat. It is only about 13 months old, could the heat element have burned out already and if so can a average repairman replace the part....
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 22, 2011 | Samsung DV218AEW Electric Dryer
My Samsung DV 338AEW, is not heating up, everything seems to be working normal, just no heat.
heatman101
Jan 18, 2011 | Samsung Dryers
I need help. Our dryer control currently works and when we push and hold the start button it doesn't start. lights work on control panel. door switch works and power is fine. last time it was used it smelt...
maybe the motor for the dryer, is this a even heat? if so here is a website:
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
if not an even heat here is another website:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 26, 2010 | Whirlpool GEW9250 Electric Dryer
The dryer will not heat. I have no error codes and everything else works fine. I did order a heating element assuming that was the issue but now wonder if I would've had an error code and it could be...
heatman101
Oct 05, 2010 | Samsung DV337 Electric Dryer
Clothes not dry but dryer turning. cleaned out
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 09, 2010 | Roper RGX4634KQ Gas Dryer
Kenmore electric dryer not heating
heatman101
Jun 20, 2010 | Kenmore 63942 Dryer
Gas dryer Unit only get hot for a few minuets then cools down for the rest of the cycle. Gave the unit a good cleaning. The proublem continues.
heatman101
May 27, 2010 | Frigidaire FEQ332E Electric Dryer
It won't heat up. Everything work like normal exc...
heatman101
May 14, 2010 | Dryers
Frigidaire GLEQ642A Electric Dryer Logo
119 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
