Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Vacuum won't turn off
My vacuum was stuck on; I removed the handle and it was stuck in the off position. I finally got it to toggle again but now it won't turn on. Any suggestions?!
  • Anonymous Jan 14, 2008
    My Hoover 6439-900 won't turn off! Same here!
    Gee, I've only used it 12 times and it's brand new in all other respects. So I need a new switch? This is not something I caused, rather cheap parts installed that aren't a very good quality. Never heard of this problem in all my years. Well, at least I know what to tell the guy. He'll charge me $75.00 by the time I get out of his store.
    I love this vacuum because it's the best, most powerful cleaner on the market. Hope you all don't have this problem with yours.
    AZ
  • stormblower Jan 22, 2008
    the vacuum wouldn't turn off so I removed the handle then it sparked and now it won't turn off or on even with the handle off. It's a very new vac and I'm disappointed that's it's not working. I would like stores that will service it and charge it to the warranty.
    President:
  • 1,673 Answers
You need to replace the switch.
Posted on Jan 06, 2008
Why does my vacuum keep cutting out
There is a break in the inner cable somewhere. have the flex replaced or if the break is near the connection to the vac get it refitted removing the faulty section. Get a competent person to do this !
Oct 18, 2014 | Vacuums
Won't turn off
It's highly probable that the Dyson power switch has gone bad.
You can buy dyson dc14 switch here.
The switch is located right behind the front covering of the neck or handle when you remove the telescopic wand. Please make sure that the vacuum is unplugged before you start this project.
May 27, 2013 | Dyson DC14 All floors Bagless Upright...
Bissel cleaner won't stop spraying water
Remove the handle and check for continuous spray.
After handle is removed, check to make sure the valve is not stuck in the down position. If the valve is stuck in the down position, push on it manually to get it to come back up. If it is stuck you may need to get a new handle for your unit. This handle is for a variety of the ProHeat models http://www.bissell.com/parts/?sc=part&productid=2775&partid=4449&cid=ccsocial
Check to make sure it will properly fit your model if you need a new handle.
May 08, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
My vacuum was working fine just a minute ago, and i turned it off to finish laundry, and now when i go to use it again, the handle won't recline... is there something stuck??
Sorry to hear you're having problems with your DC17. The cleaner should recline easily into the vacuuming position when you place one foot on the cleaner head, and tilt the handle back. If it's not doing this, please get in touch with us free on 1866MYDYSON, or email askdysonUS@dyson.com. One of our experts will be happy to provide further assistance.
Kind regards,
Jack
Dyson Customer Service
Jul 23, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My new Hoover Wind Tunnel Upright UH50000 will not turn off unless I unplug it.
First I would be sure the handle was properly installed. Remove the two screws holding the upper handle in place and tap it bacwards to remove it. Set the switch inside to the OFF position. Next set both buttons on the handle to the OFF position and re-install the upper handle. If the switch still does not turn the vacuum on and off, the switch will need replacement.
Apr 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
Dyson 28 handle is stuck in the locked and upright position. Vac runs fine, just can't get the handle to release to run the vac
On the lower right side of the body of this model is a air duct piece that can get stuck and won't allow you to use the release. Take out that piece and put it back on again to see if that will unlock it.
Nov 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Replace on/off switch on hoover vacuum
My wife picked one up on the side of the road that someone had tossed. The power switch would not turn off. I took the two bolts out of the top part of the handle, and then removed the screws along the back. This will remove the required panels to access the On/Off switch. Once I found the actual on/off button, I found it to be frozen in the "ON" position. After manipulating it for a few minutes, I got the switch to work. This machine now operates great, and I now have a Hoover :)
Nov 21, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt not turning
Hi.
Your Dc14 will have A clutch unit.
Check that when you pull back handle to vacuum that the clutch control knob which is located front lower left side of machine moves to drive position & is not stuck in off or park position.
Rotate it to drive if its at off or park when you have lowered handle.
If adter checking this you still have no brush rotation you will need to remove clutch unit to either replace thr belts or fit new clutch.
Try this site for further help http://dysonmanuals.llc.nu/
Oct 27, 2008 | Dyson DC14 All floors Bagless Upright...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
93 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
