Question about Kenmore Refrigerators
Refrigerator/freezer not cooling evenly top to bottom
I own a Kenmore side by side refrigerator freezer model # 106.52284202.
I returned home after two days to find my freezer door frozen shut at the bottom. I used a hair dryer to melt the ice at the bottom of the door. When the door finally opened I discovered that the ice in the icemaker storage bucket (in the top of the freezer compartment) had melted and dripped down to the bottom of the freezer compartment where it refroze. I cleaned out the freezer compartment and removed the panel cover from the freezer cooling coil in the back. The coils were frozen over with ice. I used a hairdryer to remove the ice and clean the coils. I plugged the power cord back in and let it run for several hours. I discovered that the fan that draws the air through the cooling coils was not turning on. The bottom shelves of the freezer and refrigerator were cold but the upper shelves were not. Without the fan drawing the cold air from the cooling coils the temperature inside the freezer and refrigerator is not distributed evenly. Is there a method to troubleshoot the problem to determine which component needs to be replaced? There appears to be four possibilities. The Fan Motor (part # 4389147)($40), the Thermostat Assembly (part # 2198202)($60), the Bi-Metal Defrost control (part # 2321799)($20) or the Adaptive Defrost Control Unit (Part # 2303822)($60). I would appreciate any help/suggestions that you might have.
K.G.S.
  • 2 more comments
  • sonne964 Dec 26, 2008
    Yes, I have a standard Multimeter for diagnostic testing.
    I have checked for continuity on the Bi-Metal Defrost Relay and the Fan Motor both located in the freezer compartment. There is no continuity when connecting my digital ohm meter to the leads on those parts (infinite resistance). I checked for resistance on the Thermostat (now at room temperature in case that matters) located in the refrigerator compartment and found a very low variable resistance between 25-45 ohms. The Adaptive Defrost Control Circuit Control Board has 13 leads of various colors coming off it including a "Test Plug Lead". I am not sure how to diagnose any reading that I might find from this circuit board or if I should make the attempt. Would not want to damage the circuits accidentally with the ohm meter, although I am suspicious that this circuit board may be the problem. This circuit board appears to coordinate the operation of the fan motor, bi-metal defrost relay and the thermostat.
    Upon closer inspection of the fan motor I discovered that the fine wire windings had broken. I was able to solder the broken copper wire. The refrigerator is operating normal. Thank you very much. Would not have been able to repair this holiday weekend with out your help. All the best for a great holiday and Happy New Year.
    KGS
  • Todd Born
    Todd Born May 11, 2010
    do you have accesss to a meter to do any electrical checks?
  • 700 Answers
Good then go ahead and ohm out the sensor and the relays to see if the resistance is close to the normat. 70 degrees is roughly 1000 ohms. relay you are lookling for continuity or open. then you can also ohm the fan motor too. let me know what you find;.that will determin whts bad and whats good
Posted on Dec 26, 2008
  • Todd Born
    Todd Born Dec 26, 2008
    if you read infinite on your fan motor then I would get a new one.
  • Todd Born
    Todd Born Dec 27, 2008
    im glad that the problem was easily solved hope the best to you and have a great new year!
Kenmore model# 79573966 - Top Freezer Ice is
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2011 | Kenmore Top Freezer Refrigerator
Water pooling below the crisper drawers at bottom of the fridge. Kenmore model #363.79262991
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Kenmore Top Freezer Refrigerator
Refrigerator and freezer not cooling/freeding
Possibly a defrost circuit problem -
1) Bad defrost thermostat
2) Bad defrost heater
3) Bad defrost timer
4) Failed evaporator fan motor.
Look for frost accumulated inside the louvers at the back panel, top and bottom. If you see it, remove food from freezer and put in ice chest. Take out shelves, get hair dryer and warm the backside of the freezer, directing air down the louvers. Then leave to sit for 4-6 hours with the freezer door open. Put towels in the bottom of the freezer to catch any melted ice.
After period of time, plug unit back in and power the unit back up. Once you know it's cooling, empty ice chests back into freezer.
If there is a problem in any of the above components, then it will show up in 3-4 weeks witht he same problem again.
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 253.52642304
feel the icemaker bottom, the heater may be on.
Sep 30, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
668 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
