Question about Sony VAIO VGN-FE550G Notebook
I have Sony Vaio Laptop. My computer turns on, i log in and it goes to a blank screen what do I do
  • Anonymous Jan 10, 2009
    my lap top screen comes on for two seconds than goes blank
Mine did this for awhile, i took it to geek squad and they said to do a system restore and that fixed the problem.
Posted on Jun 19, 2009
Why laptop screen goes black after plugging battery charger?
Try another charger and then see or it might be a power options issue
Try this
SOLUTION: If you have a second computer, use Remote Desktop by choosing 'Run', type 'mstsc', type the name of the computer with a black screen, and connect. After logging in, open 'Control Panel', and choose 'Power Options'. On the left panel choose 'Choose when to turn off the display'. On the row labeled 'Adjust plan brightness', under the 'Plugged in' column, turn up the brightness slider.
Aug 10, 2014 | Sony SVE15135CXS - VAIO E Series...
My screen is white
Sony Vaio is one of the most prominent brands of laptops on the market, and also one of the most expensive. The laptops, created by Sony, are known for their efficient processor functionality and sleek designs. While the Sony Vaio line of laptops are considered high-end, they are also prone to display problems.
Among the problems facing Sony Vaio laptop screens are blackouts. When these blackouts occur, the monitor turns solid black, and upon rebooting the laptop, light will briefly flash on only to blackout again. Additionally, there have been reports of an issue which causes the screen to flicker intermittently until it goes out all together. b> Troubleshooting b> Blackout displays and the continuous flickering of Sony Vaio screens can be caused by various issues taking place inside the laptop. It is not necessarily true that the problem lies within the LCD screen itself, with display issues often occurring as a result of problems with other parts of the laptop. You can test whether or not the screen is defective by connecting the laptop to an external monitor. If the display comes up normally, then the problem lies within the laptop's LCD screen. b> Parts b> If your Sony Vaio is connected to an external monitor and suddenly goes black, then the problem may have to do with the laptop's sleep button. The sleep button latch located inside the device may be jammed or broken, thus putting the screen in a permanent sleep mode until the latch is fixed. Encountering hissing sounds when the laptop is running indicates a faulty circuit board, usually damaged due to overheating. Display issues can also occur when certain parts of the laptop, such as the hard drive, have been replaced. b> Design b> Some owners have made complaints about Sony Vaio design flaws, specifically mentioning defects in the laptop's boards. Among the problems discovered after opening the laptop include burnt LCD fuses, as well as worn out circuits and internal latches. Some of these events may occur even in newly purchased units. Sony has not yet responded to various consumer complaints and has not yet issued any recalls in response to reported problems. b> Repair b> When repairing a defective Sony Vaio laptop screen, it is important that owners remain aware of the nine screws which hold the laptop cover and the board together. Not doing so can easily lead to further damage to the Vaio due to static electricity, and may even lead to a short circuit. For owners who are experienced in the area of laptop repair, parts are readily available for purchase, allowing for cost efficient repair. b> Extended desktop You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. or Click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop
Jan 28, 2013 | Sony VAIO VGN-CS204J/W 14.1" Notebook...
Windows will not start funny screen
Try Settings / Update & Security / Reset Laptop
Jan 15, 2018 | Sony VAIO VGN-CR390N/B Notebook
When I turn on my laptop it shows the Vaio Welcome screen and rigth after that it just goes blank with the cursor blinking at the left top of the screen. this is a sony vaio VGN AX570G model
your boot sector is corrupted. you will need to run system restore disk or reinstall windows. i have posted this solution previously so if you look in my solutions you will find it.
Feb 03, 2011 | Computers & Internet
A bit of citus soda was spillied in the top right speaker while the laptop was on and then it just shut off. Now the laptop won't start up ...the vaio screen sometimes just flashes once and then the screen...
Hi k_angelc,
Since that water is spilled inside the Computer, please do not turn it ON or connect to the AC Power. This will cause serious Hardware damages in the Computer. I would recommend that you contact Sony Service Center to repair the Computer immediately.
You can contact Sony Service Assistance Team at 1-800-282-2848 to setup a service at Sony Service Center.
Hope this helps.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Nov 11, 2010 | Sony VAIO VGN-CS220J/W Notebook
Laptop screen goes crazy
Most of the time, Press F8 or F2 while booting up.
Mar 31, 2009 | Sony VAIO Notebook
Blank screen laptop
Your SONY should respond to the following:
Look for the blue FN key, hold it down (use it like a shift key)
While holding it, look for a key, also printed in blue with a picture that is half sun/half moon. On my laptop is the F8 key. As you press the key watch the screen to see if gets lighter.
Good Luck!
About Me:
Carl DeAlto
DeAlto Computer Solutions
Jan 17, 2009 | Sony VAIO K45 Notebook
Sony VAIO VGN-FE550G Notebook Logo
130 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
