And my IMEI 358046014104633
SOURCE: installing sim card in sidekick II
hello, hope these instructions help: 1. To expose the SIM card slot, peel back the bumper from the top-left edge of the device. (fig 1) 2. Insert the SIM into the slot with the gold contacts facing forward and the cut corner facing out. (fig 2) 3. When you release the SIM, make sure it is locked into position behind the catch so it will not spring out. 4. Replace the bumper and turn on the device. Any problems, let me know :) Si
SOURCE: unlocking sidekick 3 special sim code lock !!!
Hi my name is femi, am from nigeria... i have a tmobile sidekick3, any time i on it, it has for code to unlock device...but when i insert sim it has for code to use the t-mobile service..have bein trying to unlock the phone but i dont get the code. i will be glad if my problem can be solve.....my email is...femifamous2007@yahoo;com.......... wating to here from you asap... am still wating to here from you cos i need it now.....
SOURCE: how do you unlock a sidekick 2008 ??
Hello.. I live in denmark and I just got the sidekick 2008.
I bought an Isim (ver. 2) on ebay. I payed $9.
Then I put It under my non tmobile sim card and powered it up and I could se my phonebook and other stuff from my sim. But it keept saying: emergency calls only.
Then you have to put it into a nother mobile phone to get signal. Then put it back in the SK with the Isim and then it works. Just remember to update the sim and phone with the settings from your current phone company by sms. Then it wont happen again.
It worked for me. so I hope it would help others...
Form Diana - Denmark
SOURCE: i got a digicel sim card i got a sidekick id i
The code is an unlock code. You'll need it to use a T-Mobile phone on the Digicel network. Before contacting T-Mobile, remove the battery and look at the sticker on the back of the phone where the battery was. You should locate a long number labeled an IMEI. When you contact T-Mobile they will ask you for this number and will provide the code for you.
Warning :
Do not enter any wrong unlock codes on your Sidekick SLIDE mobile
phones. If you enter over a certain amount of wrong unlock codes on your
Sidekick SLIDE mobile phone, your phone may get hard locked and
sometimes become unusable.
1. Switch ON your Sidekick SLIDE with a Not ACCEPTED SIM Card.
2. If your Sidekick SLIDE asks for a PIN code, then enter your SIM card PIN and press OK.
3. Sidekick SLIDE will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your Sidekick SLIDE is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your Sidekick SLIDE is locked to.
