Question about Reddy R70ET Utility Heater
Heater shuts down prematurly
Reddy heater 55 fires up and runs for approximately 15 minutes then shuts down. i am able to refire immediately but only runs from 5 to 7 minutes.
  • 232 Answers
If the heater runs fine for the 15 or so minutes without smoke/odor- do this
  1. check for water droplets on bottom of tank
  2. check for restricted fuel filter
  3. test photocell
  4. test safety control (reset)
You don't state whether this is a spark plug heater *or* Hot Surface Ignitor type. I made the assumption you were inquirung about a Spark Plug Heater. Disregard the list if the heater is an HSI type---- troubleshooting is different.
More troubleshooting tips for a Spark Plug Type heater
Posted on Dec 26, 2008
My heater runs great for about 15-20 minutes and then raw diesel comes out and it shuts down. I thought maybe the tank vent might not be working right so I tried running it with the tank cap off and it...
The transformer gets hot and stops making spark... then fire goes out....transformer cools down and it works till transformer gets hot...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 02, 2011 | Reddy R155D Utility Heater
Our heater will ignite and run for a few minutes then it will shut down and not refire without powerig the unit off. also there is a heavy smell of kerosene. we are using dyed kero. we have tried bypassing...
Thanks for providing the model of your heater. Most folks don't.
Your heater has a photocell eye and a computer board (ignition control). This team monitors the flame. If the team does not like the color of the flame then they shut the heater down and that is the situation you are in. Now, you must troubleshoot & find the problem. Is it water in the fuel, incorrect air pump pressure, worn nozzle, cracked plastic cover, etc.
Read these troubleshooting tips.
Nov 04, 2010 | Reddy R115DT Oil Filled Utility Heater
Reddy heater 55 runs about 5 mins the a puff of
This a classic occurance due to low fuel in the tank.
Jan 21, 2010 | Reddy Heater-30-55,000 BTU Variable
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater teasing me:)
sound like there is dirt and stuff in the fuel tank.when the heater fires up it pulls this stuff up into the filter.as it runs it plugs the filter off causing the heater to shut off.whe it shuts off the garbage falls back into the tank.when you refire the heater it pulls the garbage back up again.it never pulls it up the same so the time verys every time
Feb 18, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater keeps shutting down
check your cad cell. replace this. it is not detecting a flame. replacing the cad cell will fix your problem. when it shuts down it goes into lockout.
Oct 30, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy R70ET Utility Heater Logo
524 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
