Question about Xerox XDL-33D Black and White Copier
Xerox XC820 Copy Machine
I own a Xerox 820 copy machine. on the copy machine itself is a pic of a copy machine with three indicator lights. the left light is lit red & i do not know what it means. can anyone help?
    Problem Solver:
  • 10 Answers
Three lights are for paper jam, replace toner cartridge and replace dru, cartridge. If there is zigzag line it is paper jam if there are six small dots it is for toner cartridge and if it is one circle it is for copy cartdisge. You can contact me for mfurther support at jagpal_65@yahoo.com
Posted on Dec 26, 2008
Why do we have blank copies on Xerox XC830?
is it problem when you try to copy vis adf or its aucord in platen glass also?
Sep 17, 2012 | Xerox Office Equipment & Supplies
Duplex copying on xerox phaser 3300mfp
I have the same problem and was told by the telephone helpdesk that the machine cannot copy double-sided to double-side. The duplexing referred to is copying 2 single-sided documents onto one single sheet on both sides....Like whoever does that! This is misleading on Xerox's part . Colin B.
Jul 08, 2012 | Xerox Phaser 3300Mfp/X Mono P/C/F/S 30Ppm...
I have a Xerox XC820. I am getting dark copies with residual images from previous copies. Toner appears to be adhering to the drum cartridge. Do I need a new drum cartridge?
I have a Xerox xc820. The drum kit needed to be replaced, which I did as well as put in a new toner cartridge. The pages are now coming out very dark. Prior to putting in the new drum kit and new toner cartridge, the machine ran fine. I have tried all I know how to do and to no avail. Have cleaned the "wire", all the parts I can get to and cleaned the plate. Any help would be appreciated.
Apr 21, 2012 | Xerox Office Equipment & Supplies
In my ir3300 xerox in very light
That means that you have to clean copy glass , lenses, ccd,...maybe even laser unit if you know how.
On digital machines dirty optics means light copy, on analog oposite, dirty optics dark copies.
Just one more question how do you mean " charge toner"?
Jun 07, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Xerox phaser 6130: machine is about 2 months old,
Have you checked the Xerox support site? If not, try these links for your printer
Documentation
Drivers
Product Support
Troubleshooting
If this helps, click YES below.
Jun 30, 2009 | Xerox Phaser 6130 Laser Printer
Xerox xc830
it does sound like the toner cartridge is empty or bad.
Apr 18, 2008 | Xerox 8830 Copier
Xerox work center pro 657 comes up " memory is full" no faxes are coming in or out
NOTE:A User RAM Clear will clear the Activity Report, Error counters, and any documents in memory.
  1. Power OFF the machine. The power switch is located on the left side of the machine, toward the back, next to the Copy Output Tray.
  2. Press and hold down the [*] and [#] buttons on the Control Panel at the same time, while powering ON the machine.
  3. Release the buttons. The machine will warm-up and return to Standby mode. Memory in the display will indicate 100%.
Apr 14, 2008 | Office Equipment & Supplies
Xerox 212 copier
That is normally just a dirt issue.
Clean the following.
1. Midway down the right side door, there is a channel with a very thin wire running through it. Gently brush out that channel, then dampen a Q-tip with alcohol and clean that wire, Apply just slight pressure so you do not break the wire.
2. On that same right hand door, near where the paper exits, you will see a silver metal,"sawtooth" shaped strip. Most likely you will notice it is covered with ink. Brush it clean, if you need to take a dry cloth and gently clean it.
3. Remove the copy cartridge. Look on the bottom right side of the machine, you will see a set of contacts. 2 parallel contacts, per set. Clean all the excess ink off of those also. Dry brush or cloth. then look on the cartridge and clean any corresponding contacts in the machine.
4. Check on the upper left there is a door connector. Just make sure none of the tabs are broken on that.
Keep in mind, there are horizontal and vertical contacts to clean on the right side of the machine.
The vast majority of the time. Carefully and throughly cleaning those contacts and that machine area in general will resolve a U9. Pretty common on that machine. It is caused from the high voltage in the machine arching, due to dirty contacts.
Feb 19, 2008 | Xerox 212 Laser Printer
Xerox XDL-33D Black and White Copier Logo
388 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
