Question about Sansui 27" TV
I have a Sansui TV, and I hear sound, but there isn't any picture. I don't have cable, so I'm testing this through a DVD player.
  • nickhsoccerf Dec 26, 2008
    No, it's just completely black. And I know the bulb isn't blown, because I still see the snow on channels.
    Problem Solver:
  • 5 Answers
If the DVD is connected via component cables you need to set your DVD player to 480i. Also make sure the TV is set to the correct imput. Here is a link to the manual from Orion.
http://www.orionsalesinc.com/Downloads/27-/View-category
Posted on Feb 23, 2009
    Problem Solver:
  • 18 Answers
R u geting blue screen
Posted on Dec 26, 2008
Im trying to connect my coby dvd player to my samsui tv
Hi Maria,
You can hear the sound means your TV and the DVD player are working well. May be the video connecting cord ( yellow connector) between the TV and DVD player has gone bad. Please try replacing it. For testing, you can interchange it with any of the two sound connecting cords which have white and red connectors. I hope it helps.
Jan 23, 2016 | Sansui 19 in. LCD TV
I have a JVC HD 52g787, the sound works but no picture, The tv comes on, but the blue light just blinks, then cuts off, I have sound no picture
The problem is usually from the power or the Y sustain at the left or right side of the display when one of the large capacitor or heat sync on the capacitor even the flat power cable connection it to a main power board needs to be checked too, if the fuses on the board are blown it will need to be replaced
But after replacingthe fuses and the capacitors and still no solution,youwill need to replace the all board ..
You can also trouble shoot first before going to the board of the TV..
How to Troubleshoot an LCD With Sound But No Picture
It can be overwhelmingly frustrating when an electronic device as expensive as an LCD television set starts having problems. Luckily many of these problems are easily troubleshot. While being able to hear sound coming from your LCD television but seeing no picture may seem serious on the surface, fixing the problem involves checking a few different settings to make sure everything is set properly
Instructions
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Jul 17, 2011 | JVC HD-52G886 52" Rear Projection HDTV
VIZIO P50HDTV10A PICUTURE FLICKERS IN AND OUT CONTINIOUSLY WHILE WATCHING TV. PICTURE DOES NOT FLICKER IF WATCHING VIDEOS.
HI, you can do these troubleshooting steps and get back to me..
Instructions
Hope it helped ..
Jun 17, 2011 | Televison & Video
Tv has sound but no picture.
Hi, troubleshoot first before going to the board of the TV to be sure where the problem is from.
Instructions
After troubleshooting the above and no solution yet, problem comes too from the power or the Y sustain at the left or right side of the display when one of the large capacitor or heat sync on the capacitor even the flat power cable connection it to a main power board needs to be checked too, if the fuses on the board are blown it will need to be replaced
But after replacing the fuses and the capacitors and still no solution,you will need to replace the all board ..
Hope it helped ..
Jun 01, 2011 | Televison & Video
Cant see dvd picture but can hear sound on tv
check the video jacks make sure it is properly fitted if it still don't work remove and plug the video jack again or clean the two end of the jack and the video jack slot on your tv and player or replace the jack. If it still don't work. try other dvd or the device has a problem.
Sep 12, 2009 | Sansui VRDVD4005 DVD Player/VCR
Sansui VCR/DVD
Cant' get remote buttons to work. No buttons work so can not watch DVD or Tape but can hear sound. Without the TV/VCR button not respondingnit won't switch over.
Jul 06, 2009 | Sansui VRDVD4005 DVD Player/VCR
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
No sound
tcolson,
good day, make sure your RCA red and white marked cable connected to TV screen audio input where you also connect your yellow cable which is the video.
note: always remember color code of RCA cable
yellow = video
red and white = audio (left and right)
connection would always be:
video device yellow RCA socket = TV yellow "INPUT" socket
white and red RCA = TV white and red "INPUT "socket
make sure that all this 3 cable are connected together in a specific "A/V input"
cheers ,
mark
Jan 30, 2009 | Sansui VRDVD4001 DVD Player/VCR
Sansui SAN1880 80g dvd recorder no colour
Hi, I have a Sansui Model San1880, after I have manually program the TV channels, I don't get no sound at all only on the TV channels its got good pictures but no sound, would you please tell me what to do.
Thanks
Rod
Mar 01, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui 27" TV Logo
155 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
