Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Highlight feature was turned on don't no how to switch off
When I view my pictures in playback mode the bright area's flash. at the bottom of the screen it says HIGHLIGHT .
  • lsphillips Dec 29, 2008
    Please someone take pity on us......I have the same problem highlighted flashing areas.
    Scholar:
  • 170 Answers
Just click on the top arrow on the multicontroller twice. On the first click, the histogram will show and next normal image will show up.
Posted on Feb 14, 2009
How do you remove the white areas of a shot from flashing black when you look at the image?
What you're seeing is blown-out highlights. These are areas of your picture where the bright stuff (highlights) have been so overexposed (blown-out) that all detail has been lost. That's not necessarily a bad thing, but usually is. The proper fix is to reduce exposure slightly. Lost details in the dark areas are usually considered more acceptable than lost details in the bright areas.
If you simply don't want to see the blinking black/white parts of your picture, simply press up/down on the multiselector to select a different view of your picture.
Apr 25, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
My Canon 40D LCD monitor when displaying a photo has just started displaying white sections of a picture as alternating black then white. The rest of the photo is fine just the white flashes. Any idea what...
It's possible that your Highlight Alert is enabled. Over-exposed areas of your image will blink to indicate blown-out whites. If you don't like this feature, go to the Menu, under the second blue tab (for playback), look for Highlight Alert and Disable it. When viewing the image on a computer, the blinking will not appear however. It's just to warn you that some parts of the image is so bright that all detail is lost. I enable mine so that I know this and is able to make adjustments on the ground.
Apr 11, 2010 | Canon EOS 40D Digital Camera
Black flashing in bright areas of image when viewing
This is a tool to tell you where your photo is under or overexposed. If you use the up/down button to scroll through the display options (file info, shutter speed, filename...etc) will take you to the view where the highlights are shadowed or whited out. One of the views has no data or highlighting. Just leave the view there.
Aug 29, 2009 | Nikon D40x Digital Camera
When ever there is a picture taken there is a flicker when i view the picture in my camera it happens only on the bright spots ...ehy is it
It's normal.
The Nikon dSLRs have various LCD display modes, and one of them is called "highlight clipping warning display". Basically, when you set your LCD display to "highlight clipping warning display"(it's the mode right before the "histogram display"), it blinks white/black wherever your picture has blown highlights (i.e. where your picture is overexposed)
A histogram display is very helpful in telling whether you've got the exposure right, but to it isn't adequate by itself. With digital cameras, it's very important not to blow-out the highlights in a picture (they're similar to color positive film in that respect), since once you hit the maximum brightness, the image just saturates, and any highlight detail will be lost. A histogram display does a pretty good job of telling you how the image as a whole is doing, but what if there are just a few critical areas that you're worried about for the highlights? If only a small percentage of the total frame is involved, it won't account for many pixels. That means any peak at the "white" end of the histogram graph would be pretty small, and easy to miss (or just plain invisible). What to do? The folks at Nikon recognized this problem some time ago, and so have provided another special display mode on the D60 (as on most of their dSLRs) that they simply call "highlights," accessible via the Playback settings menu, under "Display Mode." This mode blinks any highlights that are saturated in any of the color channels. It does this by taking the nearly-white areas on the LCD and toggling them between white and black.
Aug 03, 2009 | Nikon D60 Digital Camera
Image flicker when viewing pictures in playback mode
You have the camera in Highlights mode.. while in playback use the up,down,right,left pad press it up and it will go through different displays like what settings you had the camera in when you took the picture then there is a graph screen... after that one is the highlights display which is what you have it on. Push up one more time to have it on regular playback mode. The manual explains this much better than I just did. If you have the manual you should check it out if my instructions dont help.
Mar 30, 2009 | Nikon D60 Digital Camera
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
How to turn off "highlight" image display on D-80
This happens when you accidentally press the up or down button when viewing images on the playback. If you press up or down a few times it goes to a screen that looks like normal playback but with the flashing highlights.
All you need to do is press up or down until it goes back to the normal screen.
Hope that helps!
Dec 25, 2008 | Nikon D80 Digital Camera with 18-135mm...
Flashing in a certain area on my screen
You're looking at the blown-out highlights. These are areas where you've lost all detail. Press up/down on the multiselector to change the view. Better yet, reduce the exposure to reduce/eliminate them.
Oct 24, 2008 | Nikon Cameras
D40X
that is the highlight warning. When viewing the photos, just press the up arrow to cycle to the mode of view you want.
Jul 15, 2008 | Nikon D40x Digital Camera
Nikon D40
Hey timrowan,
What you’re seeing is your playback mode is set to highlight, which flashes all the highlights (bright areas) of your images that are overexposed. If you don't like this viewing option you should be able to change your viewing mode by pressing mutiselector button to the right or left until you get to normal viewing. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
221 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
