Bunn NHB Coffee Maker
Problem for Bunn NHB Coffee Maker
The water is not heated when I put my Bunn coffee maker on
By maltais on Dec 25, 2008
My Bunn coffee marker was stored for about 1 year. I put some water in it and plug it. My model is NHB. I waited 15 minutes but the water didn't heat up and I hear no sound coming from the tank. What do you think is the problem? The element? I plugged it too fast and I burned the element? Can you help me? Can it be repaired?
Solution #1
posted on Feb 12, 2009
Not Rated)
furnoptn
Rank: Guru
Rating: 89%, 69 votes
If you plugged it in before water started coming out of the sprayhead (about 2 pots full of water poured in) you might have burnt out your element, But lets start with a simpler answer. Did you check the main burner switch on the side of the tank?
If so, then I would suspect your main heating element
Was this helpful?
Yes
No
Popular Solutions for Bunn NHB Coffee Maker
Questions and Unsolved Problems for Bunn NHB Coffee Maker
Do you recommend Bunn NHB Coffee Maker?
Answer
Answer
How much water do I put in resivior to start the coffee pot.
Answer
I have a small water leak at the back of the coffee pot. Water is coming from inside the coffee pot.... (More)
Answer
when water is put in the maker, it will leak about a cup. can it be fixed
Answer
my bunn coffee pot is leeaking water out the holding pot, then it onloy makes half a pot of coffee... (More)
Answer
my bunn is leaking water out the back
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bunn NHB Coffee Maker:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 2511
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
