Question about HP OfficeJet t65 All-In-One InkJet Printer
HP office jet T65 can't communicate with new pc
Hello and Merry Christmas to everyone!
I've just bought a new pc (Intel Core2 Quad) and the operating system is Microsoft windows XP professional version 2002,SP2. My problem is that although my Officejet t65 all-in-one was working fine with my previous pc (Intel dual Core,windows xp)now,it can't communicate with the new pc..I've already entered SETUP, located the configuration section for the PARALLEL PORT and modified it to read ECP,but problem insists,I keep getting the message "a communication error has been detected with your HP", and it seems disconnected!Does any of you have any idea what I should do here?? Thank you in advance for your attention and once again best wishes to you all :-)
Anyone can help me where i can find the driver for HP officejet T65 vista?
Posted on Feb 18, 2009
Needupgrading my cpu
ztz198,
On the top of every Intel processor is the sSpec Number, and the part number.
Intel Core2 Quad, that operates at a maximum frequency rate ('Speed'), of 2.66GigaHertz,.........hmmm,
Gateway Support indicates if the option is a Core2 Quad core, it will use Up To a 1333MegaHertz, Front Side Bus frequency rate, ('Speed'),
[1333MHz FSB]
http://support.gateway.com/s/desktop/2009/gateway/dx/dx4822/DX4822sp2.shtml
That 'narrows' it down to about 6 different processors.
Starting with the Yorkfield-6M Core technology, based on the 45NanoMeter architecture. (45nm),
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Yorkfield-6M.22_.2845_nm.29
1) Core2 Quad Q8400
2) Core2 Quad Q8400S
3) Core2 Quad Q9400
4) Core2 Quad Q9400S
Then on to the Yorkfield Core technology, based on the 45nm architecture,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Yorkfield_.2845_nm.29
5) Core2 Quad Q9450
6) Core2 Quad Q9450S
The maximum frequency rate of 2.66GHz, is actually a low estimate. It is a little higher, and rounded off to 2.67GHz.
BIOS Setup might state 2.66GHz, but a better program like CPU-Z, IMHO; will state 2.67GHz. A more realistic figure.
Does it REALLY matter? Yes, and No.
This way when you get into a conversation, with fellow minded computer geeks, you will stand out as one who knows; what hardware components he/she is using.
Also helps you determine what voltage range is being used.
What Instruction Sets are being used.
What technology is being used, and use it to know if the upgrade CPU will indeed work.
Also whether a BIOS upgrade is needed.
I'm guessing it is the Intel Core2 Quad Q8400.
How?
I cheated, lol!,
http://www.newegg.com/Product/Product.aspx?Item=N82E16883113110
Intel Core2 Quad Extreme at a maximum frequency rate of 2.93GHz?
That would be the Intel Core2 Quad Extreme QX6300,
Based on the Kentsfield XE technology, and 65nm architecture.
Uses a 1066MHz FSB.
Motherboard chipset is the Intel G43,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
(Scroll down. Is not in 'alphabetical order'. It is past the P45, and G41 )
Yep. Should work.
Makes me wonder though, about how you addressed the Thermal Paste; situation.
The old Thermal Paste MUST be THOROUGHLY cleaned off, and fresh, new Thermal Paste PROPERLY applied.
CANNOT reuse old Thermal Paste.
CANNOT reuse a Thermal Pad, IF used.
http://www.hardwaresecrets.com/article/274
Do I also assume the inside of the computer case is spotlessly clean, to include the Heatsink sitting on the CPU; and the cooling fan for it?
Heatsink was sit on CPU flat?
Cannot be even a little tilted.
For this reason I remove the motherboard, and install Heatsink.
Then I can hold the motherboard at eye level, and look across.
If a tiny crack of light shows on one side edge, of the Heatsink; then the Heatsink is NOT sitting flat.
This = No.
Four screws with springs on them, hold the Heatsink to CPU, Joe?
Yes. I know. This is so you cannot over-tighten the Heatsink to CPU.
You CAN however keep tightening, until the motherboard breaks, though. (Jus sayin')
However, if the screws are not tightened in a crisscross fashion, and tightened in incremental stages; the Heatsink may not be sitting flat.
Will await reply before going further. Post back in a Comment.
Regards,
joecoolvette
Note* Using capital letters for an entire word, is not 'shouting' from me.
It is to emphasize.
Mar 24, 2013 | Gateway DX482203 (PTGA002009) PC Desktop
Intel Core 2 Quad 8200 with a 945GCT-M3? Will it work?
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=719&DetailName=Feature&MenuID=1&LanID=0
Here you can see the supported cpu list.
The quad core cpu will not run on this mainboard.
Here is info about the quad cpu:
http://ark.intel.com/products/36547/Intel-Core2-Quad-Processor-Q8200-4M-Cache-2_33-GHz-1333-MHz-FSB
But you can add a Intel Core 2 Extreme LGA775
This should give a noteable difference compares to the old single core cpu.
Remember also to buy a bigger cpu cooling element.
Here is no upgrade for the bios.
Good luck
Nov 18, 2012 | Computers & Internet
Can I upgrade CPU to an Intel Core2 Quad processor on the HP Compaq dc5000 Small Form Factor PC Desktop?
No, the chipset (865GV) and the socket (478) don't allow it. And since this pc doesn't even have an AGP slot it means that you are forced to use only the miserable integrated video.
Just buy a new pc, this one is completely obsolete.
Mar 26, 2011 | Computers & Internet
Can I upgrade CPU to an Intel Core2 dual processor on the HP Compaq dc5000 Small Form Factor PC Desktop?
Jan 27, 2011 | HP Compaq dc5000 Small Form Factor PC...
Dg41 is the best
Please get DG41/CN/TX motherboards it the best. this is due to fact that it carries a better graphic resolution card, lates technology DDR3 SD RAM ram, etc.
Intel DG41CN Motherboard
  • Form Factor: Micro ATX
  • Compatibility: PC
  • Chipset: Intel G41 Express
  • Compatible Processors: Intel Celeron, Intel Pentium, Intel Core2 Duo, Intel Core2 Quad
  • Video Interface: PCI Express x16
  • Storage Controller Type(s): Serial ATA II x 4
  • Intel DG41TX Motherboard
    • Compatibility: PC
    • Compatible Processors: Intel Celeron, Intel Pentium, Intel Xeon, Intel Core2 Duo, Intel Core2 Quad
    • Front Side Bus Speed: 1333 MHz
    Regards,
    Pourmoi
    Dec 23, 2010 | Intel DG31PR Motherboard
    Hp compaq cpu two processor do not have the same operating frequency ranges
    can I upgrade to intel core2 quad in a hp compaq dc5700 small form factor
    May 04, 2010 | HP Compaq dc5700 Small Form Factor -...
    HP 7590 office jet pro scanner does not communicate
    The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
    Buddy
    Corporate Computer
    Over 21 years of PC and printer support/repair
    Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
    New tri-color ink cartridge prints only red
    Are the Jets clean and unobstructed? Depending on printer model, have you cleaned your print heads? Consider also it may be a defective cartridge.
    Sep 09, 2017 | HP OfficeJet t65 All-In-One InkJet Printer
    HP OfficeJet t65 All-In-One InkJet Printer Logo
    192 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
